  • Replies 47
Nice work Ben - it will be great to get some more faces coming along ... what is the rest of people's excuses?
Oh, and the needle is not that bad - you just look away and stare into the pretty nurses eyes, and you won't even notice it. By far the worse part is the glucose test in the interview .... but don't worry about that - just make sure you ask them to get you in the side of the finger, not the pad. Last time the guy did it in the side and I barely felt a thing! The needle is a piece of cake. And it gets even easier the more times you go. Both Shaun (Evil34) and I were a bit pasty and needed an extra 5 minutes sitting down and a couple of Powerades the first time, but by the 2nd time giving we had no problems whatsoever. Plus, as others have said, the free cheese/biccies/iced coffees/sandwiches makes it all go down a lot easier :P
Remember everyone too, to have AT LEAST 2 litres of water in the morning before you go. Trust me, you will feel a lot better afterwards if you have lots of water in you!
Cmon guys - one day you will more than likely get someone pregnant and she has a baby. Believe it or not, many women have to have blood after giving birth - and sometimes the platelets are used for the babies too. Or imagine someone you loves gets into an accident and needs blood? Imagine had some lazy/nonchalant/apathetic people actually gone out and given blood (rather than rely on everyone else to do it) it could have saved yours or a loved ones life. It is SUPER easy to give blood, and you really could save someone's life!
People with legitimate excuses I have absolutely no problem with, of course :huh:
Had a nice phone call from Red Cross on Friday thanking us for our support. He asked that I pass on the thankyous to all those who have donated blood through SAU.
Hope we get a big turnout on Saturday, and see you all at Red Cross (MODBURY)
Its not to late to join in if you havent already said you would like to come. It will cost you nothing to attend and you get free food and drinks and a chance to catch up with other SAU members.
yep and I will be a bit hit and run, since we have people coming over for lunch at 12pm.
Cool
Gives me an excuse to have a big breakfast as well. A bacon n egg sanga + a litre of water should keep the constitution up
-D
my being able to donate is a bit questionable this time around. been battling off a pretty heavy infection the last week n a bit, so we'll see i guess.
i'm scared of needles :yes: ......
same here.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
