  • Replies 60
Posted Images
Um, stagea is only 1680kg's, and not over 1700kgs as previously stated.
I used to own a stagea, and I have spent a bit of time in Mitch's as both passenger and driver. Now *dons flamesuit* I have to say that I would prefer the leggy myself. The thing is, the stagea is NOT a sports car and never will be - its a luxo barge. The leggy FEELS much lighter when you are driving it, it has a bucket load more kick from a standing start and the triptronic is light years ahead of the stagea IMO. I also dont believe that you can point at them and say they have crap gearboxes. I think, also as previously stated, that it is more of a maintenance issue than a reliability issue, but no matter what car it is, ALL imports share the same risks in this area.
A S2 ("facelift" model) S type would be my pick - but def try and get the hi-vis dash at a minimum. They are teh shizz.
RS4 is kinda in a slightly different price range.. lol..
the other car that wagon lovers might want to consider..
Caldina
here's a few someone prepared earlier
Too Bad you cant get the new shape for that price
190kw standard.
lighter than the others in this thread.
toyota over engineering.
gen 3 3SGTE motor
Edited by GTST
yeh not a big fan of the caldina either...the shape doesn't look right...reminds me of a extended toyota starlet...the newer one is o.k but then i think i would want a m35 instead.
see also carmen imports here in brissy. he has two of them that the ENTIRE MMCS system works :P ( I know this because I did them.)
kristian,
you speak my language.
NM35->EC5W- WGNC34 ->ST246
Caldina
190kw standard.
gen 3 3SGTE motor
Thats feral
M35 > EC5W > WGNC34 > ST215W
my lineup is a bit different...
EC5W > WGNC34 Series 1 > M35 > WGNC34 Series 2 > ST215W
the S1 stag's can look awesome with a good set of rims and lowered.. the S2's are just ugly all the time. :)
The more i see the more i like of these things haha.
Jake get a VR4 :)
lolz man i'm considering if i sell the r32...if not a legnum i will buy a galant...i like the practicality of it. heaps of space, power and rare. maybe if i can find a good priced manual i might get one.
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
