I always assumed that rwkw = rear wheel kw, rwhp = rear wheel hp
kw = flywheel kw, hp = flywheel hp.
Now all the dyno sheets on SAU read in RWKW.
This means rear wheel horse power, right ?
Lets say I got 220rwkw. It means I got 220kw at the rear wheels.
Or 220*1.34=294rwhp and 294*1.1(drive train loss coefficient. 10% is low, but anyway.) = 323hp at the flywheel(crank)
Are my calculations correct ?
Edited by robots
I'd say it would be closer to 365-370 engine hp
One thing I don't understand is than. Lets you got hks2530 turbo. 320hp turbo. And you get 210-220rwkw from it. Which equates to around 340hp. So is there a mistake in the calculations or happy dyno ?
Yeah, 15-25% so say 20% average unless your a Holden or a Ford then the factory will make it more like 30-40%.......lol. The 307kw Holdens don't dyno test at 307kw [that figure is a little optimistic].
Depends on your gearbox, diff and/or CV's, wheel bearings, clutch anything that produces friction and heat in the drive train. The more heat the greater the power loss between crank and wheels.
I use 20% for driveline loss and 0.746 for hp to KW.
So 350hp engine = 280 hp at wheels = 209 kw at wheels.
350hp x 0.8 x 0.746 = 209 rwkw.
In your case that's 220rwkw/0.746 = 295rwhp or 275kw at engine or 369hp at engine. BUT that 20% drivetrain loss becomes less as you get more power with the same driveline. So 369hp might be a tad high. Isn't this a metric society? So you have about 275kw and likely 450Nm of torque maybe a touch more.
Isnt the 20-30% drivetrain loss for a standard car?
206kw flywheel skyline - 25% drivetrain loss = 154.5rwkw which is about right is a drivetrain loss of about 50kw
If the drivetrain doesnt change and all you do is increase engine kw the drivetrain loss figure shouldnt rise very much.
A 300rwkw skyline with an upgraded clutch and flywheel wont change the drivetrain loss much
Therefore 300rwkw + drivetrain loss of 50kw (generous) is only 350 engine kw
If calculate a 300rwkw car at 25% your way off, its a 25kw difference and it grows as the numbers become bigger
:banana::huh::):huh::P:huh::blink::huh::blink::huh:
edit.. I had more emoticons to make my point but..
THE FOLLOWING ERROR(S) WERE FOUND
You have posted a message with more emoticons that this board allows. Please reduce the number of emoticons you've added to the message
lol... owned by zee germans of old
Edited by GTST
Isn't AWKW in a GTR pretty much the same as RWKW. As under normal driving conditions while accelerating, most of the power goes to the rear wheels anyway? So say if a R32 GTR makes 250kw in AWD it will make like 255kw in RWD? However i suppose with engine power there would be a bit of a difference as you would lose a bit more power through an AWD drivetrain with an extra diff/transfer case etc. compared to RWD.
So therefore it would be a bit more at the engine when comparing a 300RWKW car and a 300AWKW car. I think it will be just stabs in the dark to guess how much extra power those components take away in power loss through heat and noise.
Edited by PM-R33
At the end of the day unless you put it on an engine dyno its only estimated, its what is read at the wheels that counts.
An easier conversion from horse power to kilowatts is that 100hp = 75kw, its not exact i know but its easier to do a quick conversion with those figures.
    • Agreed, I've never seen a 260RS specific manual. As GTSBoy said it will mostly be stagea other than the engine loom https://www.hgeconsulting.com.au/stageaservicemanual.pdf
    • You'lll likely have to make do with R33 GTR for engine/tranny stuff, and Stagea for the body. I don't know that there's even been an actual diagram seen in the wild.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
