I like this!
4WD Twin Turbo 6 Speed Manual. 17K
why people spend on on a excessive kits, mesh and stupid head lights, yet run homo spec rims and standard ride height/suspension is beyond me.
Edited by steveP
  • Replies 90
yeh agreed stag with a r34 front end is sick
im lookin at possibly gettin a Scion bB though to b different
I saw a black stag with a r34 frount end driving down the bay not long ago and i have to say it was one of the hottest wagons iv ever seen :P
duno what its worth, but ill give my opinion anyway :P
going from a silvia to a galant vr4. yes a silvia is not a stagea, but its still a nissan turbo with the same feel and making the same power. and yes the galant is not a legnum, well it is, so shh lol.
since owning the vr4 ive lost interest in the silvia. the vr4 is much smoother, easier to drive, can be modded just as easily as any turbo nissan, and is so much easier to work on. ie, like even with coilovers and other mods, the vr4 doesnt feel like a track pig, where nissans do. the only reason im keeping the silvia is for a project to keep myself busy. if i had to pick one, the vr4 would be it no doubt.
I really dont know how you can compare a crappy Silvia to a Stagea :P My Stagea has a 2.5L turbo six, 4WD, leather, heated seats, twin sunroofs, 4 doors and a rear hatch, how many of those things does you Silvia have? My 32 and Stagea are worlds apart, you cant say all Nissans are the same.
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
