Hey has anyone had any experience making a normal screen into a touch screen for a car PC? I've seen 7 inch overlays for sale on sites like mp3car.com but the problem I'm having is size.
I want to mount the screen on the dash basically in the same spot the r34 GTR has it's screen but I want to keep the overall height of the unit as close to the height of the speedo cluster as possibe because I've been told that aftermarket gauges or anything else like that are okay as long as they aren't mounted any higher than the top of the speedo cluster. So that gives me about 9 - 9.5 cm max heaight for a screem.
I've found a screen that is the right size but isn't a touch screen so I was hopeing to get it converted into one somehow.
Another option I looked at was buying a 7 inch touch screen unit and hacking it up and making my own enclosure for it because the screen by itself is the right size but when you take the size of the plastic cases they come in they end up being to tall.
Any ideas guys?
https://www.sau.com.au/forums/topic/244104-toch-screen-overlays/
have you found where to get one of those GTR style screen enclosures? I've been wondering where i might get one from for a similar project.
A few others have attached a EEPC 7" touch screen overaly, apparently you can pick them up for around $70 not too sure where from though, but you might be a bit more determined to search the net than i am at the moment,
EDIT: found them http://search.ebay.co.uk/touch-screen-7-asus-eee
Edited by Vasili
Actually mate I have seen the enclosures for sale on the yahoo japan auctions.
If you check out http://www.slidewizeimports.com/ and search for r34 interior trim there'll usually be some enclosures for sale.
Getting anything in 7inch is no problem at all but I need something smaller than that. I really need something that the overall height is around the 9 cm mark.
9cm isn't very big.. it'd have to be a wiiidescreen 7".. the 7" touchscreen I have for my carpc, the screen itself is well over 9cm tall! I have a single din, non motorised item - couldn't be assed grafting things into the dash and I can put it away when I don't want it out :P
Edited by bubba
I'd recommend buying a 7" and dismantling it. I think this would be more reliable than an overlay.
Yeah I was thinking that might be they way to go in the end. Unfortunately my electronics skills are a bit poor to hack up a $500 + screen.
This screen would probably be my pick in the end http://store.mp3car.com/Xenarc_700TSV_7_TF...r_p/mon-004.htm
The height of the screen is 92.5mm which be a good size. Have you ever pulled one apart Trav?
Also bit of topic but does anyone know how I can fix the topic so it says "touch" screen not "toch"? Damn night shift is taking it's toll.
I understand you have size constraints but if I was to buy another lcd to rip apart or graft into the dash, I would go for the Samsung 10.4" panels.. US$200 for arguably the best quality lcd on the market..
http://www.gooddeals18.com/product/SHK1040
  • 3 months later...
http://www.bybyte.com/
:blink: They are US, but prices are reasonable and the contact I have had with them, they respond pretty quick (Am yet to buy from them, I went a $500 all in one head unit, 7inch touch screen with gps/dvd/ipod etc...)
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
