  • Replies 75
Repco still said $117, called aussie auto's and they said $84.95 and conventry said they would match it. So for all the qld people check out aussie auto's for your EL o2 sensor. Hope this saves a lot of qld people a fair bit of work!!
Cheers
Jayson
guys save urself the hassle and buy one at petraject in melbourne, they sell you it with the corect connector and theyre reasonably priced, i bought one for about 120... its awesome, better fuel economy and no black smoke out of exhaust anymore, no running fat, get a new one or ull be up to buy a new one again soon with a second hand one...
ahhh ill go downstairs and look the addy for ya...!! they come with teh connector, just plug straight in... very easy... all my problems were solved after that... very nice ppl too....ahh ok sorry its petroject.... mate im not sure which addy it is, but ill give u their number and u can call em up, its 9873 7006.... and sorry again, it wasnt 120, it was 90 dollars for mine, but that was an r32 one... good news for u ey
I slapped my RB20DET in to the O2 Diag mode and drove around a little just to see what it did.
On cruising and quite a pit of part throttle it flicks rich lean rich lean, it also does the same on idle except some times it would stay on rich, i would notice the car would then pop on idle.
But yer it does appear that the O2 is still in closed loop mode even when boost is only just starting to build so I guess it could off boost balls and even feel a little more gutsy when boost is starting to build.
Any one thought of using a Skyline oxygen sensor? Just had a look at a R31/VL 3.0 ltr type, and they have the exactly same type of plug, so you can just screw it in and plug it in. A lot easier I think!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
    • Hmmm, interesting. Makes me wonder whether there is bias as well. It's the cheapest fuel, so it is used for all kinds of ill-maintained shitboxes which are bound to have issues regardless. Nicer cars tend to require higher octane rated fuel and can't use it anyway. FWIW, the official NSW E10 facts page is decent.
