hi guys.. jsut installed a new turbo setup. i modified my gtst manifold for the external wastegate and then a screamer on the bottom of that but i realised it makes it lag and loose heaps and heaps of power. the screamer is too loud and isnt even making the car faster.. its not goin as good as i want it to.. how can i remove the screamer and is it worth doin. do i seal the bottom of the wastegate where screamer was.. do i just reweld it to my dump... how do i get rid of the screamer and add the power loss...if tehre are any...
thanks guys
https://www.sau.com.au/forums/topic/244228-taking-off-my-screamer-pipe/
hi just get a return pipe welded back into the dump pipe.
but having a screamer pipe wont make you loose power and also wont make it faster just louder dont seal off the wastegate its there for a reason .
hope that helps
but its a vent before the exhaust... any leak before the exhuast n muffler process its loss of power... i notice that i have more boost when im not in screamer pipe opening up.. and wen opens its hell as laggy and like its holding back... its a 3076r with about 280rkw and moves like my old 2540 HKS with only 240rkw.. lol
How did you realise this?
and how did you come to this conclusion?
A wastegate works when target boost is achieved... so before that, its shut and not 'screaming'... therefore impossible too cause lag and loose power.
If anything screamers can increase power, this is only the case if your exhaust is restrictive however. If your exhaust flows, there is no difference
refer to the first part... The screamer is not to blame. It would be boost controller/wastegate spring only.
So IMO... not worth doing as its not a problem
From a legal standpoint it should be plumbed in, but thats about it.
i dont mean lag... it seems somewhat restrictive... feels like it wants to move but doesnt when opening it up
well totally unrelated to a screamer dude... no idea how you end up with that result
It'll be...
- Boost/boost control related... ie the gate is opening too early, target boost not reached
- Tune, or something affecting it (timing of cam gears, fuel pump dying perhaps) and so on
- Clutch possibly wearing out
and other reasons im sure others can offer up
Perhaps the stupidly ridiculous noise coming out of the screaming is giving you a false feel with your car, i found that in a couple of cars, when the gate opens and its so ear piercingly loud you tend to expect so much more. Plumb it back in and you tend to feel the car pulling rather than hearing it.
Edited by Ryanrb25
    • Biggest thing is you're okay!   It sounds like between the accident, and the drive home, it was a pretty torturous trip again! On the bright side, you took the opportunity to enjoy the event more from the perspective of a spectator, than as an entrant!   Sad to see so much damage to the car. It really has taken a HUGE hit in the front end. If/when you choose to repair, hopefully the rails are straight (At least from shock tower backwards). Hopefully the extra cage coming through there has save most of the chassis rails, and HOPEFULLY saved the motor too. Best of luck when you eventually get motivated to start pulling it down to check it all out
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
