I just got the car tuned today at Hi Tech Dyno.
Boost was put up from 9psi to 12psi and made a little over 180rwkw.
I have a cat back exhaust, the rest stock. Also the electronic boost controller is not stable.
I think i have marked the correct boost settings. Bottom one is on low which spikes then goes back down.
My next plan is to replace the stock front pipe and replace the stock air box with air pod intakes plus a better boost controller.
https://www.sau.com.au/forums/topic/244405-180rwkw-on-12psi-gtr/
well airbox & pipes will be fine
There is another reason your not making power, cat perhaps or inexperienced workshop? could be dyno settings even but realistically you should be 200-220rwkw
Im running GT-SS admittedly, but i'm making 250rwkw @ 12psi - stock GTR dumps (not R34)
Before that i made 250rwkw on 1bar with the stock ECU & compliance cat...
Plenty of people running 240-250rwkw @ 1bar on the stock ECU/turbos etc, so you shouldn't be too far behind
Have i marked the correct lines for the boost? low and high?
What gains should i get with an upgraded front pipe and better cat than compliance cat and pods and boost controller?
Edited by BillyMako
looks like uve marked the right lines... but noticed the speed???
was it done in 3rd gear??? surely that cant be 4th gear...
i think the dyno operators messed up ur run
Have you run a car up in 3rd and 4th? It really makes no difference to power at the end of the day.
Edited by GTR1993
please stop looking @ ebay
For $150 - i CANNOT be good regardless of rating
y not???? aslong as it all lines up, just use plenty of exhaust cement to make sure it doesnt leak,,,after all its just a tube of steel... worst case scenario you loose $150 on a dodgey product, maby even get a refund if you threten to leave bad feed back.... in the end you could end up saving hundreds on a brand named equivalent...............
and a gtr on 12psi should be running way above 180kw,,,, my gtst with just an exhaust got 160rwkw... with the standard actuator i can only boost it to 10psi and i recon i get atleast 180kw (feels like it anyway)...
maby your engine has had a hard life or the dyno guys did a dodgey job
From what I know, Hi Tech is run by John Keen who used to (think he still does) race professionally and has worked on many race cars over the years... Always see race spec porches in his workshop and some pretty mad imports.
So as far as the workshop goes they have a pretty solid reputation. Give them a call and ask to talk to John Keen himself, pretty sure he'd be able to sort it out and give you plenty of feedback. He doesn't beat around the bush and is very straight forward with anything mechanical.
But beware, his work isn't always the cheapest. But guess that's the price you pay for quality mechanics.
he has a nice dyno setup and certainly knows how to strap the car on for max traction,
but seems to struggle with ebc setups
10 minutes dyno time = $200 WTF?
and this was on several occasions
never again.
hmm 180 Awkw's doesnt sound that bad or is that 180 rwkw??
my R33 gtr was only making 210awkw @17 psi with a new greddy boost controller, pfc, dumps cat back, air intake,cp pistons
so 180kw doesnt sound that bad for only 12 psi, unless there is something wrong with my car too.
^ your results are the sour ones mate :)
210 @ 17psi... thats nasty bad.
1. Stock turbos shouldnt be pushed that far anyhow
2. If you only made 210 with aftermarket ones, id be even more worried about something not being right
yes too high for stock turbos, thing was i was told they had bn rebuilt with steel wheels when i bought the car, only found out about a month ago they weren't so $13000 later with new turbos an some other goodies i got 385awhp @20 psi
what should i get just by adding a power fc?
powerfc SHOULD jump it by about 20-30 rwkw
I bought mine comletly stock and added a catback exhaust. Got it dynoed and it got 189 rwkw.
Eventually added front pipes, powerfc and cam gears and dynoed at 250rwkw @ 13psi. (on a not too aggressive tune too )
I gotta add, my car did come fitted with a high flow cat.
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
