Thought this may interest a few people.
I've been a long time user of Mobil 1 oil (5-50w).
I did an oil change last weekend and as the only Mobil 1 they had was the new stuff that was $68.90 for 5 litres (old stuff was $45 for 5 litres) I decided to try the Shell Helix Ultra (5-50w) stuff at $44.50 for 5 litres.
Both oils are full Synth etc...
I found that since changing to the Shell Helix that my oil temp is a consistent 7-10 degrees hotter, and oil pressure is also down.
With the Mobil 1 the oil pressure when hot and sitting on 100km/h in 5th on flat road, would sit on '4' on the factory oil pressure gauge.
Now with Shell Helix in exactly same situation, the factory gauge sits on '2' !!!
At idle (when hot) the Mobil 1 sat on '2' and now the Shell Helix sits on '1' !!
Looking at the specs on these cars, they say that the normal oil pressure at ~3000rpm should be '4' on the factory gauge - which is pretty much what the Mobil 1 gave me...
I'll see how the Shell goes in the next few weeks, but at the moment I wish I'd bought the new Mobil 1.
What have you guys found to work ??
J
https://www.sau.com.au/forums/topic/24447-mobil-1-v-shell-helics-ultra/
  • Replies 52
Guest RedLineGTR
I use Shell Helix on my car. It seem to be good for my car. I have heard from certain people thats it not good lalala...but no proof. While using Shell Helix Ultra (5-40w)(dont think they have any others in that brand) the engine temp was cooler compaired to others oil such as Motul which i used for a while. Oil pressure sometimes is perfect sometimes its abit off, but i would say it would be more of the oil pressure sender. I find that when the car has run to normal op temp and i turn it off for a minute and i start it the pressure is lower than before, not sure what it is but it gets back upto normal after some drivin.
I've only used Castrol Formula R in my car since getting it, both 5W-30 and 10W-60. The only differences between the 2 I've found are slightly less power and economy, and slightly higher oil pressure with the 10W-60.
The oil pressure with the 5W-30 is fine though, it touches on 7 or 8 when cold (especially when revving) and sits on about 2 when warm/idle. The 10W-60 seemed to go off the scale when cold (probably 8 or 9) and settled down to a bit above 2 when warm.
I might try 0W-40 next, but I think it's pretty expensive. I'll see how the pricing is next oil change.
Guest RedLineGTR
the motul oil 8100 5-40w the oil pressure was the same, just the temp of the engine would not go down to much compaired to shell. I dont believe that mobil 1 is all that good since they used so much money on those adds on tv banners etc etc...they have to add to the price. If i had the money i would use redline oils in my car all the time but i dont have $150 to spend on every oill change.
Personal opion. As long as u change your oil often the less crap will be in the oil and less wear on engine parts. Oils around the $50 mark are pretty good...wouldnt go for any for like $20. I change my oil after a long cruise of fanging or before...whenever i have some spare time and money i'll pop down to the shops and pickup some fresh oil..
Lots of different opinoins.. This is good.
I'll see how the Shell goes for the usual 5000km etc..
Might try something different next oil change. But keeping the cost of 5 litres of oil at around $50 would be good.
J
lol - just edited so Helix is spelt correctly :P
Ferraris don't use turbos. They don't need a synthetic oil. I think it's dodgy marketing on Shell's part personally :D
Also note that on Castrol's site, they advertise the mineral-based 25W-50 as being used in Victor Bray's drag car. What they don't mention is he changes his oil between runs - again the temperature/viscosity tolerance is much less important than in cars where it needs to last 5000km or more.
I've said it once, and said it again:
If you go for any sort of synth oil, and you change the oil every 4-5000k's i don't think it is an issue. We should be worried about frequency of change, not so much the oil itself. We can argue till the cows come home about whether mobil/shell/motul/royal purple etc is best, but at the end of the day any of their synths will protect your engine regardless of how hard you drive it.
Most oils are designed to be compatible with others. I would be wary of topping up half a sump full of another type of oil (even though I've done it myself) but if you do a full drain before filling up with another type then you'll be ok.
can someone explain to me what oil pressure i should be lookin for on my car?? cause i don't really have a clue about whats good and whats not ... i'm currently using penzoil 5w 60 i think after changing from castrol and i notice that my oil pressure is lower than it was when i was using the castrol ... i better change my oil too ... its been 10k LOL but thats ok cause it hardly ever reaches boost ... about 95% in vacuum hehehe
u ppls should not swap and change over different brand of oils wether synthetic or not. all oils are constructed different and behaves differently. all race car uses heavier oils for added protection but slightly less power , but power is ur game then go for the lighter oil. one thing is that mobil is a better lubricant than shell ultra , but shell ultra is more durable as in decay rate after 5000k the mobil might be dead where as the shell product might go on another 10-15000kays, so it different horses for different courses. a s a fact all the new BMW-AUDIS-FERRARIS-LAMBOGHINIS-VW-PORSCHES uses shell ultra only as a factory selected lubricant, and they also have extended their services out to 15-20000kays
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
