Guest RedLineGTR
Originally posted by Brody
I just picked up 5 of mobile1 at autobarn for $55? so ill see how I go tomorrow when i change....
Quick question, mobile1 being 5w-50, isn't that going to be 2 thick when warmed up? Thicker = slower revs?
it should be fine...alot of people use it on the forums from what i know..there is also i diff type of mobile 1...0-40w rating hard to get for only workshops from what i have heard. Would be nice to get some..
  • Replies 52
hhmmmm...then would something like castol -R be better as its rated at 5w-30?
I just took out all the black shit that was in there, topped it up with fresh mobile1, took it for a quick spin, didn't really noticed a difference....other times ive had it flushed i have :P
When u do an oil change, do u have to change the filter everytime?
I use a mechanical oil pressure gauge, if all is set up ok there is no rear problem, but unsure of legalities.
Brody, why put $50 of oil in and not spend the extra $8 on a filter just to be sure. Otherwise you still have all the old oil and dirt in the filter with the new stuff flowing through it.
mobil dont cope really well in temp department.
Thats contrary to an article i have (had?) that rated the Mobil1 as having the best high temp stability of all the oils tested (approx 8 oils from memory)
I have used Mobil 1 on this basis and with my engine having done 155,000kms, 3,000 of which have been at prolonged full throttle on circuits... it seems to have peformed well at high temps.
This is a good read, as im looking for a different oil after 6 years of using Mobil1, its getting too expensive.
Your thoughts on using say a 10-50w etc for an engine with higher kms say 155,000kms?
I found little difference between the 2 on the street. Shell was probably better because of it's pricing even temps was only a tad higher, but of no concern.
But on the circuit I like the Mobil 1. Shell, the temp rose to rapidly and went well above 130 degrees. Mobil sat at 115 degrees.
Because i forgot until i had started :D
its the first time ive done it myself...
You can get mechanical oil pressure gauges but they can't be mounted in the cabin. Hence people putting them on the bonnet.
Electrical oil pressure gauges which use a sender are fine for cabin mounting, but are more exxy and may (as someone said) have a reduced range. However as long as it covers the expected operating point of your oil around the middle of the gauge it'll be fine. I really don't think oil temperature should vary by 140 degrees!! (if base temp is 40C then 180C is your top temp.. fairly hot oil!)
Jay i fitted i remote oil filter and cooler so the filter mount had a spare fitting that i used, otherwise im pretty sure you are able to buy a plate that goes where the filter is and the filter screws to that. Remote filter is not hard to set up either and makes changing the oil very simple.
ahh
well i got a 93 gtst
and i just put helix ultra 5-40 in
and im having the pressure problems aswell
if it doesnt sit above a qtr i get very cautious
but yeah it sbeen in for 2 weeks now
and sits VERY low at times
around 5-6 at startup till its warm
maybe because it runs so hot it flows free'r?
who knows
ill dump it after 2 thou
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
