Got car tuned after fitting a front mount and it hits a wall at 5800rpm.
Took it for a spin with a laptop hooked up and the AFM voltage drops suddenly at the stated rpm. I have already done the $5 intake mode but the rubber bends felt really soft in todays heat and could be squashed easily.
What are my options here?
Also with the laptop hooked up i could see my water temp rise to around 100 degrees. I did have the ac on but not giving it a lot (33 outside). The gauge inside was still showing just under half as normal.
Is it time to fix the clutch fan? (my patrol has the same clutch fan and it howls when its this hot outside)
Thanks in advance
James
Edited by Bond
So your clutch fan isnt working... or not working well... and your surprised the temps are high?
Of course fix it, its a pretty important part afterall.
As for the piping closing over, get a metal one made. Problem fixed.
I dont know if the clutch fan is stuffed as i have not owned another skyline and not sure on what temp it should be, hence the post. Temp gauge reads normal.
Plenty of ppl here running a lot more power with standard airbox and similar filter.
Anyone know the size of the standard piping? I may have some bits around.
Temp guage is not an accurate indicator of engine coolant temp. My experience has been that it tends to read 3 modes:
So hot the engine is about to explode
Normal temp
Car is off - cold
If your clutch fan is busted, it is a pretty urgent thing to repair. It WILL explode and most likely chop your bonnet, cam cover and radiator up if the bearing is gone. It's not if, it's a matter of when.
I've actually seen a car when this has happened and it is not fun at all. the owner was heartbroken that something so cheap to fix could do so much damage - you can get one off a wrecked car for almost nothing
Wire in an aftermarket temp sensor into the radiator hoses and then wire it into your standard dash display. Works a treat and doesnt give you anymore gauges.
Not sure how its done, I bought my R32 with it already. (thank you Mr Jap man)
As for other problems, Get a new fan, flush your radiator, and get a metal intake pipe. Its only the start of summer, imagine the poor car in a few months.
Edited by JiN_MaN
the $5 intake mod, with 120mm long metal core, clamped to the rubber, is as good as any other option
once in there she cant sux closed; impossible to suck closed if done correctly - metal cant sux closed lol
better than an aftermarket unit simply cause its a do it yourself $5 / 30min modification, that really works !!
better check that clutch fan !!!!!! auto FTW I say! :P
I found my temps were going up once my radiator got a small crack
eventually she was steaming on a winters midnight run, lost a lot of water (was the 2nd radiator fitted too!)
got a bigger unit and temps have been down by a lot more than with the stock radiator, sees 4 bars cooler on the stock guage
using that blue radiator fluid
can anyone link to the "$5 intake mod" ? .. i've tried searching but can not locate it.
http://www.skylinesaustralia.com/forums/Re...l&hl=rev210
in the stagea section by user REV210
I pulled the intake pipe off today to check what had been done by previous owner. Everything seemed it was done the right way. I think it has been sucking shut on the bend just b4 the turbo as it felt quite soft and fairly easily squished by hand.
I ended up cutting a peice of pipe i had sitting around and putting it in fairly close to the turbo and clamped it in place. Took it for a spin and its now reving freely to redline again YAY!!
Also i pulled over and popped the bonnet and gave it a few revs and the clutch fan is working very well and drawing a heap of air. I might go put a new thermostat in tomorrow and see how it goes.
How is everyone else keeping an eye on their temps if the standard gauge shows no signs of running hot?
James
I fixed my clutch fan today and the temp gauge is sitting lower although it wasn't as hot as yesterday.
I did notice that the metal intake pipe connected to the throttle body was very cool even after some hard driving. It is normally very warm even hot!
I also changed my plugs to bcp.7...It had the bkp..7. in there. No more missing under boost :banana: .
Cheers
    • The obvious answer here is get a ND2/3 RF with the Targa top. The red is nicer, too!
    • This is the only point I can access with any floor jack and my car is SUV height - What's the actual suggested alternative here? I have also driven up on blocks in the past, but lets say you have a problem and the car is on it's wheels already and can't be driven up/off anything? Not a huge fan of bits of wood being spat in random locations either (it hasn't happened, but what-ifs occur) Perhaps I would also really enjoy having a quickjack :p Time to google quickjacks.
    • The wires look to be a healthy gauge, more than I would think the pump needs. I guess another concern is if the FPCM will be happy with the extra current draw. I have heard they are a bit sensitive.
    • It will be fine. The real question is whether the existing wiring is fat enough for the current drawn by the bigger pump. The 342 is not that hungry, but it will be well worth pointing an IR pyrometer, or even better, a thermal camera, at the pump hat wiring when it is running, just to make sure. Or, you know, just touch it to see how hot it is.
    • Hi guys, Sorry to revive such an old post! The fuel pump in my M35 has finally given up, the car has been sitting for 3 years so I'm not surprised. I bought a Walbro GSS342 of Scotty some time ago, so I'll throw that one in. My question is, if my car has no performance mods at all, do I need really to mod the wiring to supply constant 12V? or will the new pump be just fine at the reduced voltage at idle? Thanks guys..
