Just wondering if anybody has tried additional coolant bleeds in any of the RB range? More specifically the RB26 - there is three coolant plugs just under the coils just awaiting - not sure if its a high point but there will be a shitload of localized heating in those locations.
Edited by rob82
https://www.sau.com.au/forums/topic/244535-coolant-air-bleeders/
seen plenty of additional lines added to the inlet manifold of the RB26 - im just not sure on the exact spots - one would be the bleeder bolt towards the front.
im interested in the exact locations myself for the 26 -
here's my effort
Was there any method to your madness or is it just something that has been taken from the high horsepower Jap cars? Was there any other coolant system mods like pump impellar redesign or slowing of the pump?
I'm guessing that it cant hurt but most GTR's are running that much full load timing that the exhaust coolant ports aren't copping that hard a time. However some of the RB30 with decent street setups are running low timing numbers that will most likely put more stress on the coolant system. I guess what I'm saying is that the higher the average cylinder pressures the less the ignition timing numbers and the more stress imposed on the coolant system.
  • 10 months later...
Does anyone have more pictures of intake collector tube / manifold? Old pictures dont work anymore. I have used search. Looking right place where to weld fittings or drill and make thread. :laugh:
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
