got a brand new in box Blitz LM Sus panel power filter - blue in colour.
fits all skylines, 180sx,s13,14,15 etc.
check model listing.
$50 pick up in syd + $10 post if needed.
0413544494 or pm if interested.
fits:
SKYLINE GT-R BNR32 RB26DETT 8/89-11/94
BCNR33 RB26DETT 1/95-12/98
BNR34 RB26DETT 1/99-
SKYLINE HR31 RB20DE(T) 8/85-4/89
H©R32
HNR32 RB20DET 5/89-7/93
H©R32 RB20DE 5/89-7/93
ECR32 RB25DE 8/91-7/93
ECR33 RB25DET 8/93-5/98
ER33
ECR33
ENR33 RB25DE 8/93-5/98
ER34 RB25DET 6/98-
RB25DE
#V35 VQ25DD
VQ30DD
VQ35DE 6/01-11/06
CPV35 VQ35DE 1/03-11/06
SILVIA
(200SX) (K)S13
CA18DE(T) 5/88-12/90
(K)PS13 SR20DE(T) 1/91-9/93
©S14 SR20DE(T) 10/93-12/98
S15 SR20DE(T) 1/99-
180SX (K)RS13 CA18DET 3/89-12/90
(K)RPS13 SR20DE(T) 1/91-12/98
300ZX PZ31 series RB20DET 3/87-
HZ,KRZ,KRGZ31 VG30 series
PULSAR GTI-R RNN14 SR20DET 8/90-12/94
also got a turbo off a VQ30DET motor.
very minimal shaft play.
will fit on a RB maniufold in stock position if a RB rear housing is used (just swap it around) this turbo has got a fat mid range & very torquey, like a VG30DET and more torquey then a RB25 turbo.
pics:
$300 neg
Cheers
Edited by dori32
added: leather nismo gearknob $30, good condition
price drop: $270 on the VQ30DET turbo.
for more info, visit www.vq30det.com
also got a supra intercooler (end tanks on same side).
$40
Cheers
Edited by dori32
the vg30 rear is a direct bolt on no need to change it, thats what im using now, great to bolt onto the back of an rb25 highflow.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
