1996 Nissan Skyline R33 GTST Series 2
5 Speed Manual
100xxx kms
Deep Marine Blue
Rego ending July 09
Engine Modifications:
- Just Jap stealth front mount intercooler
- Apexi air pod
- Splitfire coilpacks
- Greddy Profec B Spec II (used as a boost gauge)
- Turbosmart boost tee (running 10psi)
- 3" to 3.5" turbo back stainless steel exhaust
- ECU remap done by Toshi
Drive:
- Ohlins adjustable coil overs
- 17" rims
- Exedy brass button clutch
Ice:
- Pioneer MP3/IPOD head unit
- Jaycar 6.5" speakers
- Jaycar 6x9" speakers
- Audioline 4 channel amp
I am selling this car AGAIN because now I just want something different. Car has run 190rwkw @ 10psi on Dyno Dynamics. Major service has been done which includes timing belt and pulley. Gearbox has been serviced with new oil and a new raidiator has been put in. Runs smooth as and is very responsive to drive. No hurry to sell as I have a whole line up of mods to put in if I do not sell it in a few months. Interested in trades so let me know what you got - r32/180/even a honda.
PRICE: $14,000 ONO/OBO
Contact details:
Andrew on 0412 773 767 or pm
https://www.sau.com.au/forums/topic/244596-1996-r33-gtst-series-2/
I'm not trying to be a massive jerkface, however 14K might be a little steep. I had your mods + more including tuned power FC and I ended up letting mine go for 12k >:(
IMO buy a shit runabout car for the weekdays and keep this for cruising on weekends, you will find a new love for the car :(
I'm not trying to be a massive jerkface, however 14K might be a little steep. I had your mods + more including tuned power FC and I ended up letting mine go for 12k >:D
IMO buy a shit runabout car for the weekdays and keep this for cruising on weekends, you will find a new love for the car :)
i dont reckon you should be dissing sale prices in someone elses thread either. pm him if you have a problem with his price.
yeah dont say it on the thread.... but i can't see what the prob with the price was anyway, if someone was seriously looking to buy an r33 they would already have an idea what to pay for the car, i recon its a good price anyway, ive seen the car in the flesh and its a very neat series 2 and well worth the $$$$
i'd buy it but mine is better even though its a common silver colour lol :huh:
keep it andrew, get a runabout lol
I am using the bleed valve because the EBC is now.. how should I put it nicely.. F*****D!! The output board has fried itself and Trust/Greddy are in trouble as they are and its hard to get the ebc replaced under warranty. So now the ebc is used as a boost gauge.
To clear the confusion alot of people have been having, on LOW boost the car makes 190rwkw @10psi, on HIGH boost the car makes 210rwkw @12psi. Currently the car is running on low boost with the tee piece as I just don't need the power on a daily basis. Used to be easy with the ebc obviously but that can not be helped at the moment.
    • Food for thought, the stock oil filter thread is a 3/4-16 UNF, which has an ID of about 10 to 12mm (according to ChatGPT lol). Now compare than to an 10AN, which has an ID of about 14mm (Raceworks is 14.2mm, Speed flow is 14.27mm).
    • Yep, totally get that. However hooking in for Generator back up is only a few hundred bucks for the wiring. You could put a couple of those in (for different circuits explicitly) and run a couple of baby generators. Bonus, you can balance them across different circuits, and now have backups in your backup. I'm looking at buying places that won't even have water etc, and I don't mind the idea of getting off the electric grid either, even with everything you've said. This country already has enough power outages that even the mains grid isn't that reliable anymore. I do agree though on spending a bit more to get better gear, and to add some extra redundancy in to the system too.
    • You can set hard reserves on your battery system, and it can't be discharged past that.
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
