sorry man, it was down that way over the christmas period, if you had of been a bit quicker i could have driven it to your door to hav a look, your quite welcome to fly up and have a look, you wont a find a cheaper better R34 in australia, i guarentee!!!
  • Replies 55
im seriously considering it man, im talking to my financial advisor (my boss) to see what i can figure out, cuz i still owe the bank some cash, im hoping to get as close too the payot figure as possible, so far tho, you are in the lead... i need more time tho man, thats considerably less than whats its worth, but as i said im desperate to sell... i will get back to you tho...
Chris
Im sorry its taken so long, but no matter what way i bend the figures i just cant sell it that cheap im sorry man, the absoloute minimum i can take is 20,000, and even then its at a huge loss to me...
the front bar u have is very similar to mine
mine is a tommy kaira front bar at the middle of ur one there is a square plate if it says tommy kaira then its the same, if it says nothing then im guessing it a fake
ill get a photo up later
I now have no license for an unset period of time (go before the judge tomrorow) and i would realy prefer my baby was driven instead of sitting around my work for the next however long... so yeah, umm, bump!
I can't believe this GTT hasn't been sold yet with all those mods incl. GCG and PFC ... damn man. Have you tried carsales.com.au ? If not, try there ..SAU has a limited audience most of whome already have a skyline. Oh and I wouldn't mention your driving record / loss of license, it just rings alarm bells to a potential buyer that it has been trashed. I applaud you on your honesty, but lets be frank ... when you're trying to sell something, you should try to only mention the good stuff. Mentioning that you're pretty much a hoon won't help you sell it. Just IMHO..
Haha, yeah man, im suprised it hasnt sold yet either... and thanks for the advice but in regards to my license issue, ive owned my baby since it had 60,000k's on it (over 2 years now), never once have i hit boost until the engine was completly warmed up, and as for any other mischevious activities, it certainly has never been drifting, it still has stock suspension in it, the HICASS is still enabled and im too scared of bending it if something goes wrong, its a 34 not quite your throw away body of a 31 or 32 even lol... i once heard a simple rule when it comes to drifting/racing... you do it long enough and its not a matter of "IF" something happens but "WHEN"... Yeah i will be honest, lets face it, its a skyline, its designed and built to be driven hard and fast, but thats far from the "thrashing" i know you are referring too... as a mechanic i know the essentials to keeping a car healthy and in good condition, i welcome anyone who is genuinly interested to have it compression tested, leak tested etc... this car is A1 mechanically sound...
  • 3 weeks later...
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
