There was a bloke in Sydney doing it for a while. But I've sent him a few emails/PM's and hasn't bothered to reply.
I've heard that the biggest hurdle is working out the programming for it, as using the R32 ECU on the R33 uses a different K factor in the programming.
Don't ask me what this means cause it's way over my head. But it's not as simple as loading the factory R33 maps into the R32 ECU. There's other things that need to be modified in the programming to make it work.
Sadly it's not a straight forward process :)
J
  • Replies 43
nissan ECUs dont only have maps but have constants for different things like automatic, manual loading and many other things which no one really knows (yet)
currently someone i know is writing a software simulator to work out what everything does on an R31 ECU
K constant is for base injector pulsewidth and would of course be different between R32/R33 ECUs
Thank you Jay95R33. Hi GTST.
I can program chip for R33. It's like a min's ECU. Call one time chip.
If you change your mods I can make another chip.
But we have to import the chip from Japan each time, GTST where can I buy HITACH chip ?
I will get five chip at the end of this month from Japan and I will be able to sell programed chip. Price $350
If some one is interested, please send me PM.
I can get a daughterboard from Japan.
It's making only one company.
Cost about $300 - 350 (only daughterboard )and shipping , tax, install, chip tune.
Originally posted by Toshi
I can make chip for R33. It's like a min's ECU. Call one time chip.
Sounds good this^^^ one! Nothing like a little homegrown ingenuity...
but like i said before.
you wont get it right first time. You'll neeed to have 2-3 shots on a dyno to get a good tune and that (wil the throw away chip) will cost a fair amount of $$$.
But if you can get daughterboards (like mine) then that's a whole different case.
Yeah, the website was playing up last night, looked like it came through three times.
The R32 has gone to finance my wedding. I really miss that car.
The R33 is a result of finding the extra funds once all the planning and preparations were done.
I wanted my R32 back but it was to no avail.
Let's just say the honeymoon will be cut short but i don't mind.
I was so depressed without a Skyline.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
