  • Replies 126
Posted Images
agreed, stags are porno.
seems its hard to find a grade 4 auto in black though.
your not looking hard enough :banana:
>>Black 260RS 25k<<
>>Black 2.5x<<
>>Black 1999<<
>>Black RS4<<
>>Black RS4<<
how about white 260RS
>>White<<
teach her to drive manual in the getz :D and say your not driving the new car until you don't crunch gears :)
pfft, you gotta be joking right?
she laks the co-ordination the be able to drive manual...
i tried teaching her in the getz a while ago,
after about 3 fat skids, 6 bunny hops and 3 years of clutch life gone, she gave up. thank god!
automagic will do, its only gonna be a family car.
you've changed man, you used to be cool
hehe..im only kidding...Appropriate choice for an up and coming 'family man'
Ben taught me how to drive manual in a suzuki ignis... then i upgraded slightly to a r32-GTR LOL.
Where bouts do you live craig? if you wanna come up to show your missus the stag maybe we'll do a bbq or something.
Jeez you could've picked a better looking one than that to try and convince people, that thing looks like arse :D
*edit* after having a decent look, the car itself isn't too bad, but the cheap looking Bob Jane-spec rims and off road profile tyres just ruin it completely. 0/5 would not watch again.
Edited by AndrewJZX100
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
