For sale: 1992 RB20DET R32 BLACK Sedan
Mods: Garret 28/71 turbo
turbo blanket
Walbro fuel intank pump
braidded oil/coolant lines
pod
Front mount( no reo bar cut) legal
Greddy profec b spec2 ebc
remapped ecu by jeff @ the speed lab
Greddy infometre (reads straight off the ecu, temp e.t.c)
Boost gauge
Replaced all heater hoses, alternator, water pump. clutch master e.t.c
Oil changed every 5000km by myself and a mate
Body touch up done by Doyle crash, (hasnt been in any crashes)
ISC rear adjustable camber arms,
new fuel filter
new tie rod ends
new rack boots
radiator flush
a/c belt replaced
new spark plugs
Recent wheel alighment
Pager alarm, sends sms to your phone, boot release, central locking($1000)
Turbo back exhaust, decat pipe, into a bee*r muffler
R32 GTR Wheels, repainted in bronze/gunmetal grey well over 50% thread
R32GTR Brakes all round, ebc green stuff pads rear and bendix fronts
Cusco Brake master stopper
extreme 6 puk extra heavy duty button clutch
chromeoly flywheel
Re-shimmed diff
cd player, 7*10s e.t.c
have stock turbo, stock lines, stock intercooler, other box of stock parts
Car has mainly been serviced and dyno at turbo tune, under jeff and michael
recent dyno results pulled 221rwkw on high boost and 187 on low boost
am selling due to i have a problem where i spend evey bit of money i earn on making the car better and i need to move into a new house and have no money, so im saving for that! no other reason as i dont want to part with the car! Am looking at purchasing an 06 stock wrx so if someone has something along those lines to trade, otherwise i will stick to finding a car myself. not interested in swapping with 180s, s13s e.t.c as i need something i wont spend money on!
condition: I reguarly get compliments on how clean the car is and well maintained it is! i also get alot of shit for babying my car along and washing her every week, the mod list can back that up, being that all the basics and necessititys have been replaced. im very anal about the car and hope that the next person will also be!
i have reciepts for around $9000 of work, theyre here in front of me and can be viewed by prospective buyers! my loss is your gain.
price: recently had an offer for $14,000 when i had no intention of selling, silly me denied, so ill put it up at $13000 o.n.o! pm or call me and we can neg.
tyre kickers and joy riders need not apply, so dont waste my time and yours
i work gay hours, so sms is prob easiest to reach me at, or try calling around 2-30pm-530pm tuesday to saturday
ph 0431 308 333
car is located in blackwood area
pics
will post pics asap when i get them off the other computer~
https://www.sau.com.au/forums/topic/245317-r32-gtst-black-2-door/
oo nice, i might come have a look sometime, i'm interested in getting a R32 or R33 soon
i'm just in flagstaff hill
Edited by Ravyk
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
