I might be able to go, but I wanna see the edd there ;P
-D
I've still got to get your rims then get the new front bar then get it and the guards painted. I'll also need to get the holes for the side indicators on the guards filled which will equal extra $$$
  • 3 weeks later...
  • Replies 448
Posted Images
ok guys......
lets get this show on the road...........
i really need to know who is a definate on entering and i need to get your entry forms and entry fee money asap please!
lets make this SAU display bigger than last year!!!
eddy why not just enter the car as it is?
im not worried about how many mods have u have or havent done to the car
because I wouldn't get 1k away from my place before I get done for no front bar......well maybe one but you get what I mean :D
awesome :) ill be organising a meet up sometime by the end of the week..........
so if ur thinking of entering or are defintly entering then come to the meeting, ill let u all know exactly when, where and what time a lil later during the week....
If i don't have any hassle's with my turbo install in the next week, then i'll most probably enter my car.
Grip practice day on the day before - I regretfully inform you I will not be entering, instead I will be suffering a horsepower hangover from going round and round the lala......
OMG
i just realised that i saw your R32 at autobahn at mile end a few weeks ago , you parked it beside my mates black r33 :(
on topic now , i cant wait for this show ;)
Now i dont know what to do! track day or this? It would be good to finally use those semi slicks that are sitting in my shed.
a. sit around all day
b. sit around all day AND race your car
My vote is for b. You know you want to :)
or perhaps:
c. sit around all day AND race your car, then stay up all night cleaning it, then sit around all the next day ;):D:D:(
cheers for that scott! i got ya down on muh list!
i really need some stag's guys!! someone please enter with a stag or two!!!!
and i need some more r31's and more r34's :P
and a r32 gtr a r33 gtr and a r34 gtr needed too!
i have plans :):)
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
