awesome :) sounds like a plan
nice front bar by the way aswell roo she looks hot as now!!!
Bored with the grille tho. Looking for something better now.
Bumper is still in black primer. Won't be sprayed by the time of show, couldn't get it into the shop ... but not rushing the job either. I want a good finish, not a rush job, so black primer it is for now.
  • Replies 448
Posted Images
yay ... Sunday will be awesome... Got invites for you roo for my Bday Party!! you had better dress up!!!!
Damo... Adrian.. i haven't seen you guys in ages!! will be great to catch up :P
:rofl:
bloody hell guy, you too must work at bolivar? you love stirrin shit :laugh:
OK, this is as serious as I will get here, then back to stirring.
There are to many people/posts in this thread that need to step back and have a look at themselves. I am hoping that by stirring a bit I can get some of them to look at their views and comments and reconsider what they have are saying.
If someone wants to set up an SAU display, thats great, but they need to remember its SAU, not a me and my homies display. (unless they want to post it up as a me and my homies display, SAU members come and support us)
I can see why some people are pissed off about not being allowed in the display, especially when it wont be a skyline display. (I don't have a problem with the Stagea's being there, but it seems hypocritical to then say other models are not welcome)
/end serious rant
OK, back to the stirring.
Edited by 4door_Sleeper
it is SKYLINES australia.............
u know what.........f*** this right up the arse im not gonna bother doing displays anymore if this is going to be the attiutude of people.
I dont blame you with all the captain bringdowns on here.
Well it seems your not allowed to have a display for Skyline/Stagea's only, I could of sworn this was Skylines Australia :laugh:
Maybe some of these people should of organised their own display!!
+1.
noone never said that they cant enter and make a display.
if you want to go in it y dont you set up a display and enter or is that too hard???
it feels like your just attacking one person to vent frustration and no matter who that person is, its who u are to whinge on forums rather than to face the facts and ask properly. you need others to back you up and make ppl feel like shit. tis not cool and childish.
how about we grow up pplz and stop acting like 12yr oldz.
end rant
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
