  • Replies 448
Posted Images
mmmmmmm that 34 gtr is pure porn. Quick chat to the owner its running a Jun 2.7L stroker, High mount T51R, 20" GTC's, 8pot brakes, midnight purple. Will post pics of the engine bay later. I love it. O yeh btw 450kw at the wheels.
Cheers Cara for organising, look forward to next yr.
Edited by Luke_ENR34
yeah that gtr was sexeh as.........ill sell all my internal organs for it any day lol
in opposed to your external ones? i thought only guys had them....
...anyone get pics? my pics over exposed for some reason:(
had an awesome day, pretty roasted, sun was quite hot when it peeped out from the clouds.
Had a decent rofl when a buick won 2nd best import and when "dragon" took multiple awards home, but we all had heaps of fun, even tho Cara had a dildo in the car.
Sounds a bit like sour grapes? (perhaps?)
For the record the voting slip advised that the import class was "A vehicle that is imported into Australia" so a Buick would qualify.
The 180 isn't everyones cup of tea, but if you had a closer look you would have seen a lot of modifications have been done to that car. I think it puts out over 250rwkw, and has numerous internal and external mods. (some subtle, others not) It was also one of the few cars to set up a significant display, so it was probably more memorable to the general public when the time came to vote.
guy the car puts out 160 kW
and most people will actually agree that the car has almost been slapped together........
Not quite :geek:
follow this link to the SMASA website
Dragon 1994 nissan 180SX
SR20 turbo black top 260 kil watts rear wheels, HKS 4'' exhaust, HKS pipes, rebuit motor last year with s15 runing parts HKS top cams, HKS forged pistons, S15 fuel injectors, naprec 100mm throttle body . HKS t51r single turbo
17x8 Adrenalin wheels, fully airbrushed and decked out inside, no rear seats just a SOUND SYSTEM 3 pioneer 350 watts amps, 2 Pioneer 10'' subs, 1 Pioneer 12'' sub, Pioneer CD tuner 4+50 with ipod, Pioneer DVD player.
And its hard to call it thrown together when its been evolving for at least 7 years that I know of. It has been in various car shows, & the SVD Car Club events that I have seen.
Edited by 4door_Sleeper
its a seriousFAIL regardless............i never seen this car on the dyno at Autosalon or Extreme Horsepower.........if it soo powerful why not enter a dyno comp then?
Edited by MissR34
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
