Dragon 1994 nissan 180SX
And its hard to call it thrown together when its been evolving for at least 7 years that I know of. It has been in various car shows, & the SVD Car Club events that I have seen.
...a very well planned fail?
  • Replies 448
Posted Images
nice pics, looks like i missed out on some fun.
traditional questioning of the award results :geek:
dragon mobile clearly has a 5 star multiplyer rating as per need for speed addons.
let it go kids you wouldnt like people nit picking your cars :)
Edited by Inline 6
yeah Chris, Jenkies and Carl all revved their cars and we got a warning over the PA :geek:
oh well i dont give 3 hoots bout what happened, i was their for the social side more than anything, and was about time my car got a decent clean!
yeah i rekon that was carl's fault - i heard someone in our area start their car up and the next minute the guy with the mic is like do not start ur cars up at all
lol
same here damo - i didnt go in there expecting to win anything...........i just happens sometimes....i really wasnt expecting to get 3rd in the import class
it was a really good day and an awesome catch up too with everyone i havent seen in awhile :geek:
Edited by MissR34
dragon.. does anything need to be said? :facepalm:
shopping list, chinese (not jap) stickers, neons, mesh, oh so gay rims, ride height, too much pointless red hose, a gay theme primary school kids would have made up.
saw it driving down the road once, almost crashed coz it was such a head turner.. woops did i say turner. i mean shaker in disgust. oh well some people are just born clueless.
should have got off my ass and taken my car out, meh.
Edited by steveP
i agree the dragon car was not good but suprisingly as it may seem most people think their own car is the best.
were they a bit tight on space this year? last time you guys got to spread around the place as i recall.
Edited by Inline 6
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
