Gt35r Vs Garrett T04z - Discussion (just Post In This Thread To Create A Database)
Correction - you will need to run two external wastegates - one for each bank of collectors which feed into each scroll of the turbo. Like this sr20 manifold:
you only need to run one...
just merge the two wastegate collectors together
thats how my 6 boost t04z spli manifold was done
Thanks for your input. I currently have a 3582 .82 on a 6boost manifold, response, power are all very good (refer to earlier posts in this thread) but boost control is a real problem - believe it or not the current build was a result of similar boost control issues with an internally gated xr6 turbo so I'm essentially back to square 1 after more than a year of building the thing. Seeing as the manifold needs to come off regardless I'm looking at options - which is where the FR stuff has come in.
I dont want to go with another 6boost manifold, but over 4k for a fr manifold isnt appealing if they arent perfect either.
nick, didnt brad (scradly) have a chat to you about how to sort out 6-boost problem?!?
That is one way to do it....but not the best way. Geoff at full-race found there is stronger pulse energy by utilising two separate gates as he found there was a small discernable "leakage" from one gate tube to the other under the single gate method.
The problem is that you need to have a small gap between the divider and the external gates outer valve face (to allow for thermal expansion) because if the valve touches it may not seat and seal properly .
For the nth degree you need two seperate wastegates - be they integral or external .
A .
my gate runs directly off the exhaust housing. all custom from etm manifolds. wat u guys reckon btw its a t04z .81 rear and everything is ceramic coated. :P will be goin onto a tomei 2.8lt stroker motor :)
Thats one way of doing it though it limits you to that turbine housing .
ATP is starting to sell turbine housings with bosses cast in for external gates but possibly not T04 sized .
A .
Bottom line is that we have to convince the manufacturers that we need twin scroll twin integral gate turbine housings because it's the simplest neatest solution , makes the manifolds straightforward and the bypassing and dump layout soooo easy .
Garretts TS Evo 10 GT3076R IW turbo should not be under wraps too much longer , all cake .
well just to add to the topic of GT35 series turbos, manifolds and twinscroll setup's
im running a GT35 with anti surge compressor housing with .78 divided exhaust housing ATPturbo.com did all the work on the turbo B4 sending it over to me
the exhaust manifold is a custom steam pipe item, it only runs 1 external gate each part of the collector has a pipe coming of it feeding into a external gate
after putting the setup on the dyno and getting it tuned i realli should of modified the manifold to suit twin external gates because i have no boost control wat so ever
even with the boost controller set of 0psi it still peaks to 20psi (the only crap thing now is i already got the manifold coated so modifying the manifold now means i need to get it coated again )
the car made 400kw on BD4's dyno a few weeks ago but had problems with fuel pressure
ill be getting the problem looked at some time this week
will post up new results when every thing is finished
Edited by STR8E180
Hey,
a) The only things I can think of that would cause this is if the outlets to the gate; the gate itself; or the pipework aft of the gate is too small (not because you have 1 rather than 2).
If you make the gate a screamer, is boost still uncontrollable?
If you put a bigger gate on, is boost still uncontrollable?
If you take the wastegate off completely (put some pipework in to redirect the gases out of your engine bay :P), still uncontrollable?
b) You should just be able to cut away the merged part and weld flanges on each side for twin gates; you shouldn't need to get the manifold recoated unless you really want to...
Regards,
Saliya
Hey,
Regards,
Saliya
a) the gate is alread a screamer a
havent tried putting on a bigger gate and i dont think putting on a gate will help enuff, im sure it will help but i dont think it will waste enuff exhaust gas to be able to control boost
havent tried running the car with out a gate its to much work making a pipe just to redirect gas, ive only got 1 v band flange and im not using it for a test pipe
b) u cant weld onto the coating so any modification's done to the collector will need the coating removed b4 any welding can be done which means ill need the manifold coated again other wise it will look pretty crap if the whole manifold is coated but the collector
I dont think twin gates will fix the problem...the problem is very little back pressure and flow resistence to and through the turbo. The gasses are bypassing the wastegate pipe almost completely....if you chuck a gt30 on or something with a smaller turbine housing creating more back pressure it will control boost/ or atleast better then atm. Other wise you need to make the wastegate pipe protrude more into the collector to create a little turbulence so it tries to catch some gas and force it towards the wastegate, or mount your wastegate straight off the turbine housing where it is in the gases flow path.
With the merge collector style manifolds, they are great for flow and aiding turbo response, but as a result of the design they suffer from boost control issues when you have descent sized turbos on there with little backpressure in the exhaust side of the system.
If you check your wastegate manufacturers booklet they normally show how it should be mounted....and im fairly certain it should be mounted at a minimum of 90 degrees off the flow path or less. I think at a 45 is ideal and the way to go.
im using a .78 divided exhaust housing on a 2.6L engine i dont wanna go any smaller then i already have
i also dont have enuff room in my engine bay to be picky about my external gate mounting if i had enuff room to mount my external gate at a 45 degree angle to help wastegate flow i would have
Edited by STR8E180
My bad, i meant the gt30 as an example, not as something you should do.
Well if you cant mount it at a better angle to increase flow to the wastegate, then maybe mount it right off the turbine housing if space allows...otherwise i dont think you will be able to control boost with that setup.
Try welding some extensions off each half of your waste gate pipe in each half of the collector protruding into the exhaust flow a little, it might help direct some of the gas into the wastegate.
Hey,
You're going to fab up for twin gates because that's easier than trying a larger single gate or buying a flange and dummying up some pipes for testing?
If you say so :)
You also didn't mention whether:
* the gate was tested off the car (maybe faulty gate or incorrect spring?)
* any signal-altering devices like boost controllers were bypassed and/or tested separately (maybe faulty signal?)
* the size of the gate you were using
I think that testing the kinds of things I've mentioned is way easier than re-manufacturing part of the exhaust.
Further, the test results should tell you whether what you want to do will be able to fix the problem.
Still, to each his own...
FWIW a single HKS 50mm gate seems to be able to control boost just fine (the lowest I've gone is 15psi) on my 26 T04Z 0.84 twin-scroll.
You only need to remove the bare minimum of coat to weld the gate flanges on (say a 2mm strip next to each flange, not the entire manifold).
Performance-wise there's no way that forces a recoat... if aesthetics makes you do it then fair enough, to each his own.
Regards,
Saliya
Edited by saliya
I know someone who has a gt42r he had huge problems controlling boost with his turbosmart 48 gate he made bigger wastegate pipe re done the manifold still no fix, he put on bigger 50mm gate and woolah fixed it that extra 2mm who would have thought lol
What spring does your wastegate have inside Stre180 20psi possiblly? Keep your spring as close to your target boost as possible so your controller doesn't have to work as hard...
i dont like the idea of causing a restriction in the manifold just to try and control boost
the spring is a 14psi spring
Is there an issue with running 20 psi, that boost curve looks pretty good.
i have no issue at all running 20psi which is why i been to anal about fixing the problem yet
Further to the above - if you are considering a FR manifold you may want to confirm whether it is a straight bolt on fit for you car.
I'm fitting a FR TS manifold to my s15 and I've had to have a bracket made up to lower the aircon compressor 30mm and have had to relocate the power steering resevoir further around the strut tower and make up new ps lines. The 2 gates are also an extremely tight fit.
I also had to open up the flange plate on the manifold to match to the exhaust ports and tidy up the manifold collector a little with a die grinder. If I was to do it again (or the manifold cracks) I would give Kyle a call at 6Boost to make me up a manifold as it would also suit the right hand drive layout whereas the FR manifolds are primarily designed around left hand drive cars. Having owned both types of manifolds (but not tested both) I prefer the 6Boost manfold as the flange plate is the correct size and the tube welded onto the flange plate on the 6Boost manifold is flared to suit the port flange size.
My 2 cents
Here's an example of what I was talking about above regarding opening up the flange face on the FR manifolds. This particular FR manifold is for an evo and you can see that they have opened up the flange face to match to the port (admittedly evo motors have reasonably larger exhaust ports). Unfortunately, I didn't receive my manifold with this mod and had to take to it with a die grinder myself.
    • I have been being VERY quiet about what you're alluding to, as it is something that ticks me off... The number of cars from factory that run coil overs is HUGE! Most of them these days do... The other part that annoys me, is people saying "Well all the incabin adjustable suspension is illegal by blah blah blah"... If that's the case, then why can I buy a car brand new that can do it if, FULL STOP in cabin adjustable suspension is illegal...   Also, I could just chuck some aftermarket shocks in my car, throw the stock springs on, after my blue slip, dump my super low springs back in. Same shock and spring style setup... Hell, they could also be the same colour springs etc.     I'm voting, BlueSlipper didn't want to touch the above car for some reason. Whether it be some sort of bias against the car, the owner, them maybe having previously done dodgy shit and now they're being super careful in case they get slapped in the face by the Gumbyment again... Find a new blueslip place.   And can confirm as you had said, yes there are holy bibles of vehicle heights, and all sorts of other suspension stuff. Heck your run of the mill mechanic, and tyre shop has access to all of that stuff. It's how they do wheel alignments...
    • Funny story Heading to Sydney this morning on the HWY there was some slow traffic, so I gave it the beans and midway through my overtaking "power run" I lost all power It seems that I missed a hose clamp,  and the MAF and filter went WiFi To make this more problematic, the little tool kit that lives in the boot, is sitting in the sun room at Goulburn......LOL Luckily for me I found a bit of steel on the side of the road that could be used like a rusty and bent flat head screw driver to tighten it up enough that it got me into Sydney, it is now all tight like a tiger with the aid of a 8mm socket Note to self: Use my brain and double check stuff, and always keep that little tool kit in the car for when I have a brain fart
    • Oh, and as for everyone with their fuel economy changes, I switch between E10 and 98 in the company car. Even do when I had personal cars that could run on E10. You know what changed my fuel economy in any noticeable way? How I drove, and where I drove. Otherwise, say on full tanks of just back and forth from work only (So same trips, same sort of traffic), couldn't notice a difference that I can correlate to the type of fuel in use. In the current vehicle, that's over 42L of USABLE fuel. While 98 is all "more energy dense", it also has higher knock resistance as it takes more energy to get it to ignite too. The longer hydrocarbons, typically more tightly bound. So running the same ignition map, can also produce less power, if there isn't enough time to get it all burnt through properly, as yep, the flame propagation speed is different from lower octane fuel to higher (Higher has a lower flame propagation, due to the more tightly bound and harder to self ignite funs. This is also typically where, a vehicle that is designed purely to run on 91 (Whether it be E10 or normal 91) usually sees absolutely no real world difference in fuel economy for the normal man, woman, or dog.
    • We've got some servos around me that have 91 with E10, 91 (no E10), 95, and 98. At those stations the change from 91 E10 to 91, is typically around 8c/L.   But lets not get started on the price of fuel in Oz. It's ridiculous. All the service stations around me, bar one, the price of fuel has been over the $2 mark per litre for the cheapest, 98 being around $2.45. That one service station is a CostCo, fuel from it comes from the same refineries, and makes no pitstops, it runs great, including the 98. In fact, I've had no issues on CostCo fuel, but plenty of issues at other stations!. The CostCo fuel, was $1.65 roughly this week for 94 with E10. $1.88 for 98. Servos directly across from it, $2.10 for 91 E10, and $2.48 for 98. The part I had to laugh at? If I drive multiple HOURS away from Brisbane, say out near Nanango, or Kingaroy, or even out to Goondiwindi, the price of their fuel, is the same as what it is at the CostCo... Oh, and that BP servo at Goondiwindi is HUGE and goes through epic turnover of fuel, so it's not sitting there for weeks going to shit. And what blows me away, my mate is one of the people who drives the Fuel Tanker all around QLD, delivering to all those places. At the same company his previous role was doing the "local haul" deliveries... Same truck, same driver, same pickup point it all comes from. So you tell me, how the hell it is 60c/L CHEAPER for fuel, when nearly all else is equal, except they require a B-Double to drive half a day out of Brisbane, and half a day back, every second day, compared to the delivery that can be under 30 minutes drive from the fuel pickup point... Not to mention, go five blocks down the road, and Ampol to Ampol will vary 30c/L... And I've had this conversation with my mate... The way it's priced, is just typical, pure and utter rubbish... He also does runs from Brisbane, to all over QLD, down to Newcastle, Sydney, Nowra, Melbourne, Geelong, and even out to parts of the NT depending on the companies needs. His main stuff is all the longer distance away from home for a few days at a time, then when he's back, he loves to just pickup extra shifts wherever he can in whichever truck, hence all the weird different places.   Oh, as for getting E10 into all the fuels in Australia... It was very quickly highlighted, that we don't have enough biomass available to use to make E10 sustainably like they require, and it would dramatically cut into our, and the worlds food chain supply...   I vote we all just start running on liquid methane gas... Plenty of that just getting tapped off at tips from underground decay... (Note, this is pure just stupid commenting. I could very easily highlight the reasons its not a good idea especially on scale...)
    • Am I correct in assuming that the R35's are getting the classic skyline haircut off the odometer?  Quick search on carsales, there are 33 08 and 09 GTR's for sale, only 2 of them have more then 100,000km's on them (116,075 and 110,000 respectively).  And somehow there are about 25 for sale with around 60,000kms? Looks like the classic skyline haircut to me =/
