posted it in the wasteland, but figured id post it here just incase.
goin to take a spin in the 200. and i figured with all current controversy regarding cruises, id invite people too. come out, chillax, have a drive and enjoy. if you feel like coming along, call me up 0408961657.
:P
https://www.sau.com.au/forums/topic/246396-goin-for-a-drive/
guh, dont you people use phones? :wub:
woulda messaged ya andrew, but well, id left before you posted..
hit *a certain road in the north*, was rather fun, first time ive driven it. definitely showed the weaknesses of the 200 mind you.
200 :laugh: that aint no skyline hope that was you refering to how much your new skyline pulls at the wheels
uh... yeah! thats right. :P
will probably be doing something tonight aswell, starting about 8-9. so if youre keen post here or send numbers via pm and start with the sms'ing. meet point will be sent to you and route will be kept off the forums.
Edited by scandyflick
when are you going? i thought youd all be in bed by now
got back from the run i started this thread for a little before midnight. but;
will probably be doing something tonight (as in, wed 26/11) aswell, starting about 8-9. so if youre keen post here or send numbers via pm and start with the sms'ing. meet point will be sent to you and route will be kept off the forums.
PM sent :)
cheers. :)
I'd be keen, but I have a dinner tonight :)
it wont be starting til about 8, so if youre done by then and still keen, shoot me an sms and ill let you know whats up. ;)
i would have been down for the drive last night dave but you know i got soccer on
and as for tonight i dont know
might see you at villies though
no worries bud.
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
