Hi there,
After getting my NEO turbo hi-flowed (GCG), the turbo specialist at the shop I went to told me I needed to do an oil flow test, with the oil feed line to the turbo, with the turbo off.
Has anyone done one of these before? Surely the flow of a standard RB25 oil feed must be known? Only been done about a million times before...
Still I thought it best to test my specific situation...
Only problem is, I can't get higher than 250mL in 15 seconds, which works out to ~1 litre per minute. I was advised I needed minimum 1.5Lt/min (so 375mL in 15 sec) and no more than 2Lt/min. This is with an unrestricted banjo bolt in the engine end of the feed tube, no banjo bolt in the "catch end" (in the bottle which represents the turbo), and one of the banjo's has a restriction.
The line is new by the way; I had Pirtek make up a stainless one using the original banjos from the original oil feed line.
Does anybody know if 250mL is right, and what sort of flow I need? What can I do - spend another $100 to get another line made up, and then try that in the hope that I've gotten the restriction right?
thanks
DaveB
https://www.sau.com.au/forums/topic/246540-turbo-oil-flow-test/
You need to drill out the banjo bolts to get the desired oil flow - I had this issue with my RB30E+T, I think I ended up with 400ml in 15 seconds which was bordering on high-ish, but never had smoking from the exhaust due to excessive oil intake.
This has had the ball bearing CHRA replaced with a bush bearing core as I understand happens with GCG highflows, yes?
easy fix if your worried about your oil issue and the GCG turbo, ring the boys (GCG) on 02 9708 2122 they have never let me down and offer spot on info to customers, they also do ALL our turbo work (hi-flows, rebuilds). They are only Hiflow guys i can use reliably without fear of boomerangs.
Edited by URAS
Thanks a heap for the replies guys, that puts my mind at ease a bit more... for the record the GCG hi-flow of the stock turbos is a complete new Garett core, and is ball bearing.
I was told I needed between 1.5L and 2L per minute, I got ~400mL in 15 seconds. Glad to see yours was similar crayman; I'm sure this info must be known for the stock RB25DET engines - I mean it's only been done about a million times before. Still, I guess I know that my setup specifically is safe.
For the record I have found, that the stock line is fine for flow if you just drill out the banjo *bolts*; they have about a 1mm restriction in *both* of them. If you drill them out on an RB25 (NEO in my case) you should get around 400mL/15sec at idle.
PS Thanks URAS, that number may yet come in handy :)
Edited by DaveB
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
