  • Replies 102
Originally posted by ApacheX
its been....2 years....they are talking bout marrage!
Well, if he really is happy then perhaps you should just be happy for him. Do you want him to come out with you for his benefit or for yours? All you can do is indicate that you are still his mate and want to hang out. If he chooses to stay under the thumb then it may be time to accept that he's to gutless to take a stand. Either that or he doesn't wanna come out. But that's prolly not the case.
Originally posted by INASNT
Question for you
Has terrance logged in as wardest and posting shit again? :D
No Dude, I can assure you that I am not Terrance.
Althought I find your suspicion rather interesting. Were you bullied by a Terrance in primary school? I don't mean to pry but the Shrink in me emerges sometimes when it shouldn't
its is a general consensus around here that when some1 posts shit around here terrance has something to do with it.
Talking about therapy, u were quite shattered when mzdefected got enegaged werent u?? how that therapy going theses days?? :D
PS my gfriend is studying to be a doctor of Physiology so i will hook u up with a few free sessions if necessary!! hehe
I agree with the conclusion about Terrance but you have my word that I am in fact the one and only Wardest.
I wouldn't say that I was shattered but one usually regrets a missed opportunity. Although I never met Ambz in the flesh.
You seem fine Denham but I am worried about Pred. He seems to habour a deep resentment for anything which causes him to remember his childhood. He may need years of care before he's a well rounded person again. Of course he may just needhis Line back. Thats prolly the best explanation.
Originally posted by YRL05S
Wardest,
In regard to the old analogy about the plumber having leaking taps and the builder never having a fully built house, so what is your story? You come onto a public forum offering free emotional advice, i suggest you look after your own backyard first.
I wouldn't say that I've just "come onto a public forum" I've been around for a while.
In any case, my story is not the question here. You seem to have taken issue with my behaviour. Could you have been hurt by someone you trusted in the past and are therefore wary of anyone offering to help you?
hehe..the knife cuts deep wardest!
maybe it only by gazing within you can discern the unending need to analyse others in your goal of dispelling your own feelings of pointlessness....
you might want to look into that :D
Me hurt? Not likely, i am just concerned about yourself and your rejection from Mzdefected and the fact you might need to feel wanted by allegedly helping others.
I can't help it, I have a lot of love to give:D :D
Dude, an SR20DET powered Datto 1600. You don't need therapy. Your head is obviously screwed on the right way.
Nice work on that.
Ok guys, I'm back. Anyone need any help?
I'll be here till 4:00 today. Then I'll be off playing golf.
I hope you all had as pleasant a lunch as i did.
First I had 6 Oysters, au natural with a sprig of dill and a squeeze of Lemon.
Then I had roasted Pheasant with a garlic and rosemary sauce. With baby carrots, scallop potatoes and steamed broccoli.
Dessert was a simple crepe' with strawberries and rich vanilla Ice Cream.
Gotta love Florentino's
yeah wardest I'm thinking of getting my dick pierced going the full monty and getting PA .
should I do it my self or pay some one to do it.
also will I stll be able to piss straight. will Iahve to sit down while pissing or can I stand up .
will I be able to piss around corners .
what kind of psycological effect will this have on me.
will the sex be better?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
