Awwwwwwwwww shiiieeet!
Straight off the back of a successful meet, cruise and dinner, it's time for another!
The moustache touting monkey is heading back to the defect state for his birthday, and what better way to welcome him home than to hold a meet in his honour (just an excuse for me to eat some duck)
The regulars already know how good these meets have been in the past, and I'm sure plenty of new faces will be there to bask in the monkey's glory as the opportunity does not present itself often!
Meet point: Monash Uni carpark, Clayton Campus, Corner of Wellington Road and Princes Highway
Time: 9pm.
If there's enough west siders looking to make the trip, let me know and I might organise a pre meet in the west somewhere.
So come down and meet the guy that hands out the bans, and be a part of what will no doubt be another massive meet.
Shouldn't even need to be said any more, but no stupid behaviour will be tolerated and plates of offending cars will be handed to the police if necessary, in addition to club memberships being suspended.
  • Replies 148
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
