lol @ having to enforce that a pat on the back isnt gay... which leads me to believe that everytime you pat pat's back you are doing it in a sexual way...
lol :)
White R33 and R32 4 doors are gay
>_<
* put on flame suit for the Alfa
lol someones jelous they dont have a skyline anymore :)
  • Replies 148
anyone cruising in from tulla :D might need a lift from the airport if my car's not ready for the road on friday
so you might not make it to your own meet?
Nick has his license back, I'm sure he'd LOVE to come and pick you up :)
This is tomorrow night guys, should be a good turnout as always.
ABSOLUTELY NO STUPID BEHAVIOUR WILL BE TOLERATED
I won't hesitate in handing your rego into the police if you choose to ruin the night for everyone by trying to be a hero
not that rock kung is that good anyhow
heathen... instant ban for sullying the name of the Rock Kung Duck gods.
car's gonna be ready for tomorrow... mind you it'll be rocking unpainted fibreglass parts and bog... but still driveable.
ill second that
an your car well be donated to SAU for parts, for our 10 year in the making BBQ trailer
Guest
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
