do you rewrite the values in the inj screen too add or remove fuel or do you do it in the inj correction screen for exsample
at 5000 rpm's i have a AFR mixture of 12.6 if i needed to add more fuel i would rewrite this value to 12.0 and that would be it for that load piont at that rpm ?????????
Does anyone know of a link for the fc datalogit (using it and its functions for the rb25det's)??????????
thanks agian mate.
https://www.sau.com.au/forums/topic/246850-how-to-add-or-remove-fuel/
yes mate i have the lm2 unit
this is AFR log in 4th gear Full throttle at 12psi i need to get 12.0 AFR on full load how do i take away fuel???????????
Edited by MJTru
i have red the instuction and i'm lost i have no base map like he talked about i have a fc datalogit for a skyline not a celica.
lots of things are bifferent. i understand that the method is the same but he is way to confusing in his way of teaching.
thanks for the link mate as with many more reading i should get it .
I dont use the excell formula to adjust it, will get close but it's not perfect, i just highlight the cell ( cells ) on and around the cells in the inj map and use the " - " and "+" buttons, press it five times and go for a squirt.
i generally use the correction values to see how far up or down it has to go and adjust the values on the map from there. When im getting it close i only adjust the cells on the map to fine tune it.
this is my inj map
400800120016002000240028003200360040004400480052005600600064006800720076008000014.714.714.714.714.714.714.714.714.714.514.514.514.514.514.514.514.113.813.513.1144614.714.714.714.714.714.714.714.714.714.514.514.514.514.514.513.813.813.813.512.5192814.714.714.714.714.714.714.714.714.714.514.514.514.513.813.812.512.512.212.112.1241114.714.714.714.714.714.714.714.714.714.514.514.514.513.813.812.512.512.212.111.8289314.714.714.714.714.714.714.714.714.714.514.514.514.513.113.112.112.112.111.811.8337514.714.714.714.714.714.714.714.714.714.514.114.114.113.113.111.811.811.811.811.8385714.714.714.714.714.714.714.714.714.114.514.113.813.912.512.511.811.811.811.811.8433914.714.714.714.514.514.714.714.513.513.813.813.813.812.512.511.811.811.811.811.8482114.714.714.714.514.514.713.914.513.513.813.812.812.112.112.111.811.811.811.811.8578514.714.714.714.514.513.913.913.912.813.513.512.812.112.112.111.811.811.811.811.8675014.714.713.214.513.213.913.913.912.813.513.512.511.811.811.811.811.811.811.811.8771414.714.713.214.513.213.913.513.112.512.512.512.511.811.811.811.811.811.811.811.8867814.714.713.213.213.213.913.513.112.512.512.112.111.811.811.811.811.811.811.811.8964214.714.713.213.213.213.513.112.912.112.112.111.811.811.811.811.811.811.811.811.81157114.713.513.213.213.213.513.112.912.112.111.811.811.811.811.811.811.811.811.811.81349913.813.513.213.213.113.112.812.111.811.811.811.811.811.811.811.811.811.811.811.81542713.813.513.213.113.113.112.812.111.811.811.811.811.811.811.811.811.811.811.811.81735613.813.513.213.113.112.512.812.111.811.811.811.811.811.811.811.811.811.811.811.81928413.813.513.213.113.112.512.812.111.811.811.811.811.811.811.811.811.811.811.811.82121313.813.513.213.113.112.512.812.111.811.811.811.811.811.811.811.811.811.811.811.8
what do you guys think of this map when looking at the full pull AFR map.???????????
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
