do you rewrite the values in the inj screen too add or remove fuel or do you do it in the inj correction screen for exsample
at 5000 rpm's i have a AFR mixture of 12.6 if i needed to add more fuel i would rewrite this value to 12.0 and that would be it for that load piont at that rpm ?????????
Does anyone know of a link for the fc datalogit (using it and its functions for the rb25det's)??????????
thanks agian mate.
https://www.sau.com.au/forums/topic/246850-how-to-add-or-remove-fuel/
yes mate i have the lm2 unit
this is AFR log in 4th gear Full throttle at 12psi i need to get 12.0 AFR on full load how do i take away fuel???????????
Edited by MJTru
i have red the instuction and i'm lost i have no base map like he talked about i have a fc datalogit for a skyline not a celica.
lots of things are bifferent. i understand that the method is the same but he is way to confusing in his way of teaching.
thanks for the link mate as with many more reading i should get it .
I dont use the excell formula to adjust it, will get close but it's not perfect, i just highlight the cell ( cells ) on and around the cells in the inj map and use the " - " and "+" buttons, press it five times and go for a squirt.
i generally use the correction values to see how far up or down it has to go and adjust the values on the map from there. When im getting it close i only adjust the cells on the map to fine tune it.
this is my inj map
400800120016002000240028003200360040004400480052005600600064006800720076008000014.714.714.714.714.714.714.714.714.714.514.514.514.514.514.514.514.113.813.513.1144614.714.714.714.714.714.714.714.714.714.514.514.514.514.514.513.813.813.813.512.5192814.714.714.714.714.714.714.714.714.714.514.514.514.513.813.812.512.512.212.112.1241114.714.714.714.714.714.714.714.714.714.514.514.514.513.813.812.512.512.212.111.8289314.714.714.714.714.714.714.714.714.714.514.514.514.513.113.112.112.112.111.811.8337514.714.714.714.714.714.714.714.714.714.514.114.114.113.113.111.811.811.811.811.8385714.714.714.714.714.714.714.714.714.114.514.113.813.912.512.511.811.811.811.811.8433914.714.714.714.514.514.714.714.513.513.813.813.813.812.512.511.811.811.811.811.8482114.714.714.714.514.514.713.914.513.513.813.812.812.112.112.111.811.811.811.811.8578514.714.714.714.514.513.913.913.912.813.513.512.812.112.112.111.811.811.811.811.8675014.714.713.214.513.213.913.913.912.813.513.512.511.811.811.811.811.811.811.811.8771414.714.713.214.513.213.913.513.112.512.512.512.511.811.811.811.811.811.811.811.8867814.714.713.213.213.213.913.513.112.512.512.112.111.811.811.811.811.811.811.811.8964214.714.713.213.213.213.513.112.912.112.112.111.811.811.811.811.811.811.811.811.81157114.713.513.213.213.213.513.112.912.112.111.811.811.811.811.811.811.811.811.811.81349913.813.513.213.213.113.112.812.111.811.811.811.811.811.811.811.811.811.811.811.81542713.813.513.213.113.113.112.812.111.811.811.811.811.811.811.811.811.811.811.811.81735613.813.513.213.113.112.512.812.111.811.811.811.811.811.811.811.811.811.811.811.81928413.813.513.213.113.112.512.812.111.811.811.811.811.811.811.811.811.811.811.811.82121313.813.513.213.113.112.512.812.111.811.811.811.811.811.811.811.811.811.811.811.8
what do you guys think of this map when looking at the full pull AFR map.???????????
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
