mine is at 1pm....hehe i will get there a bit earlier as well so might be able to catchup with ya mate
goodluck to both of us aye ;)
yea, ill probably see ya there... usually they are running pretty late so i should still be there at 1
and yea good luck mate, lol... i'll need it... i've never passed regency first time before... even if everything is fine they always manage to find something like a tiny leak somewhere... :(
Edited by Rocky88
+1
Once the initial raping has been carried out; If you have a list the next time you go there they will only check whats on the list.
A good question for officer Neil.
A bit like when I filed for divorce. The Magistrates Court kept sending the application back with minor edits all the time. Even made an appointment, went in and sat down with one of the admin people. Sure enough, a week later my application turned up in the mail yet again for more amendments. Grrr. They had to find one item at a time. 9 months (since the initial lodgement), 2 adjourned hearings, and more than 8 submissions later ... I'm finally divorced.
Reasons for returned divorce application ranged from:
- mispelt surname (which it wasn't, I know how to spell my own surname idiots)
- witness signature not identified as meeting requirements (it was a Proclaimed Police Officer idiots)
- affidavit of notice served not correctly filled (it was according to their first instructions)
- application missing pages, must resubmit with missing pages (pages 5 and 6 were removed by them because the ex and I had no kids to declare) Duh!
- affidavit of notice served in person not correctly served (did not serve to ex-wife - she authorised it to be served to a third party idiots)
- cheque for fee not enclosed (umm, yes it was, try again!)
- affidavit of notice served via mail (one tiny little boxed was not ticked - could have advised me earlier)
There must be some real bright sparks working in the Courts :)
Fail.
Edited by RubyRS4
i got done for tyres. all 4 had worn the inside edge out unknowingly!?!?! plus they were borrowed tyres while mine get re-rolled. the cops were at strath this morning(big set up like 5-10 bikes, had a r33 pulled over on the opposite side and were pulling everyone over inc bikes). they were good, open and honest. not attitude at all. told me things to make sure i check before i in for my inspection.
4 years and first actual run in with them.
Update, got it cleared yesturday night after work. so tis all good again
Booked my revisit for Thursday at 3:40. Gonna take it to the cop shop so I can atleast drive it. If I go down there with a hi-flow cat and its loud, will they defect me for it? Or will they just put it on the hoist and check off the stuff I failed for the first time? This baffle plate cannot be good for this car, its so slow the turbo barely spools.
go to your local hardware store Rok and get a 4mm T piece
lol the car is all good to go tomorrow...hopefully it passes first time
how did u go m8? ...i failed  :D
ride height was apparently too low even tho its stock and i passed with exactly same suspension setup 2 months ago... then apparently blue globes are illegal - wtf... and a little piece of rubber that goes onto engine mount had a small crack on it...
i know i shouldnt, but i lost my temper and told the guy that it all bs... he also wanted to defect me for not having all 4 screws in my front number plate, but i got so pissed off at him that he asked for second opinion and eventually let it go...
i swear regency is fkn tough now...
sorry mate, didnt have much time to talk to u there... i was late coz i got locked in my own backyard lol
Edited by Rocky88
Yeah, they are getting really really picky. I think everyone should really try to avoid having over the top mods on their car, Regency has just gotten that bit more stricter resulting in $1,000's to just get the car there only to fail it again.
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
