Why would it cost more? Do you know what engineering means? A qualified engineer just looks at the relevant ADRs and make sure that the work has been completed in a saftisfactory way so that it is structurally sound and safe. If it meets all of these conditions and nothing needs to be done you are just paying for a few hours of research and inspection nothing more hence the low cost.
Rolls is correct. Your paying for engineer to come out, tick that its road worthy and that is it lol. If its not done properlly thats when he may get expensive. We did lots and lots of them when I worked at Sinergy Motorsports.
When Rory certified my brake bias in my 1600, there was a fee involved for the use of AIR to test the even braking of the car front and rear. It was something like $80-$100 for use of the venue ... was a few years ago. In total I paid something like $150-$200.
when i built my ac cobra replica between rory and doug potts it cost me about 2 g in reports including hire of air for lane change test and braking test . and when it went thru regency to get ticked off and registerd regency still argued over some of the stuff sighned off by the engineers and i had to go back for further reports . the whole industry is a sham lol .
My car just went through today for an engine swap and state rego transfer inspection (same as a defect basically). They picked me up for lack of child seat restraint anchors, need to get 3 of them installed. There is a hole in the drivers seat where the frame comes through, need to stitch this up. Spoiler had been removed so I had no eye level brake light. Need near wheel bearings for the rear as there was almost a centre meter of movement sideways, both front upper control arm bushes were fairly well worn as well.
Not really that fussed, wheel bearings and bushes are something I would have done myself as they are pretty damn important. Child seat restraints is annoying as I will never ever use them, I guess ADRs are ADRs though, same goes for the hole in the seat, don't really know how this could ever hurt anyone, its not even uncomfortable. The brake light is fair enough though, I didn't realise that the spoiler had one in it.
They didn't say anything about my engine swap, mods in the engine bay or chopped up inner wheel guards so I'm fairly happy as all of that stuff would be a pain in the ass to get around and fix.
I picked up a pair of them child restraints anchors at Nisswreck for $20($10 each), just the anchor and the bolt - thats all I needed because I've already had the hole and thread in the parcel shelf for them from compliance.
Or if you need the whole child restraint kit its something around $95 at Singery Motorsport... he seemed "iffy" on the pricing saying like yeah its about $90 then later its like about $95 yadida, said he was going to order it in will get back to me in a couple days when they arrive but never got back to me about it!
If I get just the anchors is it just a matter of drilling a hole and screwing a bolt through them? Or do the anchors have a bolt thread on them and need a threaded hole to screw into?
I'll give all the import guys a call tomorrow.
the hole in the seat is in case something electrical shorts out in the car, or it gets hit by lightning (it does happen). wouldn't wanna be touching an exposed piece of metal in that instance haha.
i could be thinking wrong, i am pretty knackered after all.
but uh, doesnt lightning need a route to ground?
im fairly sure rubber (tyres) prevent this from happening.
correct me if im wrong though.
Yes but lightening can jump from a cloud to the ground so Im sure it can jump from a car to the ground. However lightening takes the path of least resistance, the metal in your car has far less resistance than your body so you wouldn't have any current travel though you. Once again the chassis is ground in your car so even if something shorted to the chassis it would just flatten your battery, you couldn't receive a shock from it.
Drill 1 big hole for the bolt to go through and you also need to pot rivet the actually metal bracket to the car as well.
So bolt through, metal bracket,rear parcel shelf and then nut on the bottom.
Pot rivet the metal bracket to the rear parcel shelf.
    • Thanks. Yeah I realised that there's no way I'd be able to cover the holes with the filler, it would just fall through. Thanks again @GTSBoy!
    • That was the reason I asked. If you were going to be fully bodge spec, then that type of filler is the extreme bodge way to fill a large gap. But seeing as you're going to use glass sheet, I would only use that fibre reinforced filler if there are places that need a "bit more" after you've finished laying in the sheet. Which, ideally, you wouldn't. You might use a blob of it underneath the sheet, if you need to provide some support from under to keep the level of your sheet repair up as high as it needs to be, to minimise the amount of filler you need on top. Even though you're going bodge spec here, using glass instead of metal, the same rules apply wrt not having half inch deep filler on the top of the repair. Thick filler always ends up shitting the bed earlier than thin filler.
    • Welcome to SAU, looks like you've picked up a nice one! Any plans to spend more money that you have on it until you hate it?
    • Also I cut away the top metal that was bent as there's no way I could have gotten it level and the rust stopped. I can also see clean metal under the windscreen. So it looks like this is the extent of it. The lower metal here is also strong.
    • Is this ok and then I don't need to patch the holes? Or is it not as good as separate fibreglass repair as well?  https://www.supercheapauto.com.au/p/septone-septone-glass-fibre-filler---500g/3151.html#q=Filler&lang=en_AU&vid=itBd4yPRKxscpBbIMOhvMg%3D%3D&start=10
