Hey guys
I've just got a 1996 25X (RB25DET RWD non-turbo) with no mods and it's awesome! It's been running like a dream, clean changes no shudder and lots of low range pulling power. I am just a little worried about a transmission fault
Twice now I've been driving along and the "check tranmission" light comes on. The engine stalls and the power steering siezes up. Both times I'd just been using 2nd gear to engine brake down a windey hill. I guess it might be overheating but I've checked the transmission fluid and it's clean and full.
I really don't want to hemmorhage money on a AT fault when all I really want is a clutch and a proper gearbox!! But until I am rich enough to rip the bloody thing out does anyone have any ideas about what's going on?
https://www.sau.com.au/forums/topic/247202-transmission-problem/
run the 4AT transmission diagnostic, could be something simple like a bad connection or faulty solenoid.
http://www.skylinesaustralia.com/forums/in...t&p=3605428
I've got a series 1, is the diagnosis programme different from s2? For starters there isn't an "auto" mode on my AT switch
Cool done that. After the initial long flash it does ten short flashes and then repeats, so I am guessing a S1 2.5 gearbox is more similar to an S2 RB20DE box. But that leaves me where I started - no diagnosed faults. I double checked the radiator is full and working well so maybe the stall is just something I will have to live with until I get rid of the auto altogether.
Cheers for the help :P
reading your first thread again, sounds more like an engine problem. Usually when you get an A/T fault the A/T light will flash, not just come on, and record a fault in its log.
the next step would be to try the ECU diagnostic, there's a few threads on how to do this, basically find your consult port and jumper 2 specific pins together for a few seconds after turing on ignition, then count the flashes. let me know if you cant find the info.
yes, you can use the paper clip method, bottom left 2, marked in red.
Maybe your harness is unclipped and hidden somewhere around the fuse box.
Attached thumbnail(s) img-resized.png Reduced 93% http://post-a137279-P1020246.JPG' target="_blank"> 1920 x 1080 (756.52K)
Is this what I'm looking for? Which 2 pins do I bridge and which light will flash? Are these the right codes (below from the same thread) and am I expecting a big flash followed by the code or does it launch straight in?
ECU Diagnostic Codes
11 Crankshaft position sensor
12 MAF sensor circuit (air flow meter)
13 Coolant temperature circuit
14 Vehicle speed sensor circuit
21 Ignition circuit
31 ECU (ouch!)
34 Knock sensor
43 Throttle position circuit
45 Injector leak
51 Ignition circuit
54 Auto signal to ECU
55 All OK
http://www.skylinesaustralia.com/forums/in...t&p=3569100
it will just flash the codes straight up, and keep repeating them
Sweet I did the paperclip thing and it blinked 5 long 5 short. 55=all ok?
Looks like it will remain a mystery. Having said that it hasn't stalled once since I've started messing with it so maybe I should just roll with it.
It's really good to know all this stuff though for future reference. You're a legend chook cheers
you never know, maybe the ecu's are just like pc's, they need to be reset / rebooted (which happens when codes are extracted) every know and then.
Wouldnt hurt also to unplug and replug the ECU and the A/T ECU to eliminate a bad electrical connection there.
I take it the plugs are in the same place behind the coin tray? Where on this pic?
Is the ECU the black box above the multicoloured fuse thingey?
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
