Hi ive been having this issue for a month know i did all the normal stuff like new fuel pump, coils, new crank angle sensor, afm so on but hasnt solved my problem if any one has any idea on what to do next please let me know as i can not drive the car its really annoying. :)
https://www.sau.com.au/forums/topic/247206-r33-dying-randomly-while-driving/
You can do an ECU diagnostic using a paper clip and shorting out two pins on the consult port, a code will flash on the dash. Do a search for it on the forums, the ECU will supposedly remember problems for 50 or so starts. May help shed some light...
Edited by MintR33
Does the car idle roughly or abnormally?
i got that problem fixed it did idle rough got a new crank angle sensor and went away just dyes randomly know say ur driving and out of no where will loose all power and stop
does it idle when you slow down, after applying a tiny amount of boost. i've been having this problem as well. we figured out that the car stalls when you apply boost, even if its a little bit and then you come to a stop or change gears. i think its sumthing to do with the turbo , but then again i mite be wrong
i hope its not the turbo cars gonna send me broke lol :)
I would say it's an electrical problem, possibly one of the relays controlling the injectors or coilpacks. Maybe check the plugs (onto the relays) first, then try replacing the relays.
Sounds like your ignitor if its a series one (being that year it should be) which is located in the engine bay, S2 is actually bundled in with the ECU inside the car to avoid this problem. As it warms up (and its on its way out it) it should cut power to the coilpacks. Once its cooled (or using a cool shorting trick) it should start again. Replace or reposition it away from the engine to fix. Common on RB30's with the ignition module under the dizzy
Hey mate, I just collected my car from the workshop. I was having the same problem as you. I just did my 100k service..the mechanics told me the timing of my car was abit off which was causing the dying of the car and i had a boost controller installed which tuned my turbo. My car is driving fine now.. maybe you should check the timing.
Cheers!
Cheers!
Thanks man ye i got all that checked all turned out good engine runs like a dream my tuner is saying it can be your alarm kicking in when you are driving which imobilises the engine and shuts offf all i gotta say
SKYLINE OWNER SHIP= STRESS and ALOT OF FUN
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
