Hi i have owned this car for 4 years now and have decied its time to move on so its up for sale.
R32 GTR 1989 model
190k kms on the tacho about 20k kms on the engine and most parts
black in colour
Price 30k
engine
87mm Arias forged pistons
P.A.R billet rods with 7/16 rod bolts
ACL race bearing
Crank balanced,grub screwed and JUN crank collar
block acid bath, decked and oil returns bored out.
Head rebuilt fitted with bronze value guides.
Metal head gasket.
Modified sump larger and fitted with tomei sump baffles.
Covers have been coated by Craved and new R34 Nur centre plate.
JJR catch can
SARD 800cc injectors
SARD FPR
Tomei 260in/out cams
HKS cam gears
Gates timming belt
N1 oil pump
N1 water pump
Nismo oil cap
Nismo harmonic balancer
Nismo fuel pump
Nismo AFMs
Nismo engine mounts
Ms/k&n air pods
Apexi power FC
Turbo
HKS 2530 turbos currently tuned to 21psi
HKS dump pipes
JJR front pipes
high flow cate
kakimoto exhaust
Cooling
JJR 40mm radiator
JJR silcon radiator hoses
JJR cooler piping
JJR 100mm inter cooler
JJR oil cooler(not fitted)
Nismo radiator cap
Handling
GAB coilovers
Cusco strut brace front and rear
Steering rack rebuilt 20k kms ago
exterior
18x10+18 WORKs XD9
Work blue wheel nuts
Nankang NSII 265/35 tyres
N1 front bar vents
QFM 750 brake pads
slotted discs
standard GTR brakes
Nismo fuel cap
Interior
Nismo gear knob
Nismo Steering wheel
Blitz ID III boost controler
Apexi 60mm boost gauge
MP3/CD stero
Think thats all i can think of right now sure i have forgot a few things .
There are some bad points car has a small dent on bonnet and drivers door plus a small tear in drivers seat and non work AC.
Im in no hurry to sell this car i may keep it as the next thing to do is respray it and it wuld be perfect
No silly offers price is 30k i dont care what others are selling for, car Ran 11.693@116mph on the 19/11 probly could do a little better but who knows.
Was one of the top cars on the skid pan last Texi and has only been to wakefield once with no timing.
Oil is change every 5000kms by DART Automotive who built the engine. Car was Tuned 500kms ago by Unigroup was tuned for power under the curve not peak power.
Also have some other parts like HKS twin exhuast and 17s.
Plates dont come with the Car tho if you want them Pm me an offer.
Contact via PM, [email protected] no Mob number as i work shift work will give my number to anyone who ask for it.
Price 30k
https://www.sau.com.au/forums/topic/247256-heavily-modified-r32-gtr/
This car makes some scary power!!!
I've seen the car go from pretty stock to a pretty rocket.
Who ever buys this is definately getting a bargain!!!! It's pretty much a new car!
Bumpity Bump.
This is an awesome car, have been in it many times and its so fast it absolutely scares the CRAP out of me. 30k is a bargain when you consider all the top quality parts and effort put into this build.
Id buy this in a second myself if I had a spare 30k lying around.
  • 3 months later...
this is a beautiful gtr - i ran an 11.1sec with 5kw less than what u have here just to give others a better idea of your cars capability
dart has always been my choice of mechanic :devil:
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
