Hi i have owned this car for 4 years now and have decied its time to move on so its up for sale.
R32 GTR 1989 model
190k kms on the tacho about 20k kms on the engine and most parts
black in colour
Price 30k
engine
87mm Arias forged pistons
P.A.R billet rods with 7/16 rod bolts
ACL race bearing
Crank balanced,grub screwed and JUN crank collar
block acid bath, decked and oil returns bored out.
Head rebuilt fitted with bronze value guides.
Metal head gasket.
Modified sump larger and fitted with tomei sump baffles.
Covers have been coated by Craved and new R34 Nur centre plate.
JJR catch can
SARD 800cc injectors
SARD FPR
Tomei 260in/out cams
HKS cam gears
Gates timming belt
N1 oil pump
N1 water pump
Nismo oil cap
Nismo harmonic balancer
Nismo fuel pump
Nismo AFMs
Nismo engine mounts
Ms/k&n air pods
Apexi power FC
Turbo
HKS 2530 turbos currently tuned to 21psi
HKS dump pipes
JJR front pipes
high flow cate
kakimoto exhaust
Cooling
JJR 40mm radiator
JJR silcon radiator hoses
JJR cooler piping
JJR 100mm inter cooler
JJR oil cooler(not fitted)
Nismo radiator cap
Handling
GAB coilovers
Cusco strut brace front and rear
Steering rack rebuilt 20k kms ago
exterior
18x10+18 WORKs XD9
Work blue wheel nuts
Nankang NSII 265/35 tyres
N1 front bar vents
QFM 750 brake pads
slotted discs
standard GTR brakes
Nismo fuel cap
Interior
Nismo gear knob
Nismo Steering wheel
Blitz ID III boost controler
Apexi 60mm boost gauge
MP3/CD stero
Think thats all i can think of right now sure i have forgot a few things .
There are some bad points car has a small dent on bonnet and drivers door plus a small tear in drivers seat and non work AC.
Im in no hurry to sell this car i may keep it as the next thing to do is respray it and it wuld be perfect
No silly offers price is 30k i dont care what others are selling for, car Ran 11.693@116mph on the 19/11 probly could do a little better but who knows.
Was one of the top cars on the skid pan last Texi and has only been to wakefield once with no timing.
Oil is change every 5000kms by DART Automotive who built the engine. Car was Tuned 500kms ago by Unigroup was tuned for power under the curve not peak power.
Also have some other parts like HKS twin exhuast and 17s.
Plates dont come with the Car tho if you want them Pm me an offer.
Contact via PM, [email protected] no Mob number as i work shift work will give my number to anyone who ask for it.
Price 30k
https://www.sau.com.au/forums/topic/247256-heavily-modified-r32-gtr/
This car makes some scary power!!!
I've seen the car go from pretty stock to a pretty rocket.
Who ever buys this is definately getting a bargain!!!! It's pretty much a new car!
Bumpity Bump.
This is an awesome car, have been in it many times and its so fast it absolutely scares the CRAP out of me. 30k is a bargain when you consider all the top quality parts and effort put into this build.
Id buy this in a second myself if I had a spare 30k lying around.
  • 3 months later...
this is a beautiful gtr - i ran an 11.1sec with 5kw less than what u have here just to give others a better idea of your cars capability
dart has always been my choice of mechanic :devil:
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
