RB30:
- Full set of Federal and Mogul cast pistons only, no rings - better than stock rb30e pistons.
to fit standard bore size - use standard rb30e piston rings.
$200
- Standard Rods + Pistons + Rings in good condition.
$50
RB25:
- Air con compressor
$150
- Short block - has pistons, crank and GTR rods bolted on only - good for rebuild:
$300
RB26:
- Standard pistons, came off R32 GTR with 89,000km - good condition
$100
R33 GTST:
- Custom turboback exhaust with changeable diff-back section to stock - mild steel - 2yrs old
$250
RANDOM:
5x 14x8 + 1x 14x9 wheels (i think) - bought these and they didnt fit on my skyline.
$200
Autogauge gauges - water temp, oil temp + oil pressure in bracket to fit into DIN pocket.
comes with all senders and sandwich plates needed - used
$80
I'll update the thread when i find more stuff in my garage.
Contact via PM.
https://www.sau.com.au/forums/topic/247292-rb30rb25rb26r33-gtst-parts/
wouldnt happen to have some rb pickups u want to offload?
I'll check my garage but i doubt it mate.
all pm's replied.
guys, im a bit slack in getting pics up because of work bla bla...
the gauges are the smoke faced gauges from just jap that are black when they're off and light up when you turn the ignition on.
UPDATE: found a boost controller to go with the kit - i will sell the entire kit for $100 with the 4 gauges + oil pressure plate/switch. i couldnt find the water or oil temp sensors anywhere. they go for around $30 for the water temp adapter from justjap and around $5-10 ea for the temp sensors.
pics up.
Note: stock rims in pic do not come with this set.
post-13452-1229316100_thumb.jpg post-13452-1229316108_thumb.jpg post-13452-1229316130_thumb.jpg post-13452-1229316153_thumb.jpg post-13452-1229316164_thumb.jpg post-13452-1229316178_thumb.jpg post-13452-1229316200_thumb.jpg
Edited by SECURITY
Where are you located? I need an air con commpressor.
im in bankstown. pm sent.
Can you tell the reason why those wheels didn't fit your car?
they dont clear my brakes. with spacers i think they'll fit, they are a skyline stud pattern though.
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
