hey guys, this JUST happenned today when i was driving back home from work. the car felt really heavy, ruff, when in gear. also noticed that the oil pressure bar was just one bar away from 8kg/cm3. i never really take not of the oil pressure, but i do know that the ideal 4kg/cm3. is that correct. is this a potential problem? any ideas whats goin on?
https://www.sau.com.au/forums/topic/247305-oil-pressure/
Not sure, but I'd say a big end is on the way out, you have an oil blockage, probably at the big end journals, your motor is in dire need of a rebuild. If you keep driving it you will kill it big time.
But I'd get a second opinion, bl##dy hard to diagnose over the web........
https://www.sau.com.au/forums/topic/247305-oil-pressure/#findComment-4294842
yikes, how much would a rebuild cost btw??
https://www.sau.com.au/forums/topic/247305-oil-pressure/#findComment-4295303
If it was cold and when you first started it up, c'mon, oil pressure will go to 8 and your car will be a bit rough until it warms up. If its happening when its warm, thats a different story.
thats what i thought at first.. but the oil pressure keeps going up to the marking below 8 even when the engine has been running for a while. goin to xspeed on friday to get it chkd out..
https://www.sau.com.au/forums/topic/247305-oil-pressure/#findComment-4296455
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
