the bilsteins are circlip height adjustable, its not as easy as threaded sleeve adjustment, but fine if u dont plan on changing height all the time. you can however put threaded sleeves on the bilsteins to make it easily height adjustable like any other coilover package.
well, after having a look over coilovers prices, I would include any dampers into the list again.
that damn japanese yen is not getting any lower, everyday it's higher and fkin drier :D
currency exchange rates kills me. difference in prices around %30-35 increased!!
is it possible to use my Teins' springs and fit them on a set of different brand shocks?
or, maybe someone here have a second hand set of coilovers and wants to sell it!!
cheers.
Anyone know what is the optimum ride height for the Greddy Type S and Bilstein with Eibach springs for the R34GTT? Don't wish for it to be too low because my ride has a full bodykit that's scrapping half the town humps.
hey mate,
would you please tell me waht springs rate you have on those monoflex? and how is the ride on pumpy streets?
how long you have them on your GTS?
The spring rate is 8kg front and 6kg in the rear. We have had the shocks revavled by Graham and Mike at Fulcrum Suspension in BRisbane to suit what we do. The car is basically a track car (half caged, stripped weight etc etc).
With the higher spring rate than the super street, on the track we found a few issues with understeer etc. A few swaybar adjustments, shock adjustment and different wheel alignment specs fixed the issued....mind you it took a while for it all to 'come together' again as we were very used to the super street...so it was much a learning curve.
As for what its like on the road....its firm. However with the shock absorbers set towards the softer end of adjustment the drive on the road is quite bearable and the smaller bumps tend to have the harshness taken off it if that makes sense.
If you want to know anything more, just let me know. Happy to help where i can.
The springs will probably be a straight up 2.5" ID spring....so it will fit on any other coilover that uses a 2.5" spring. However, the free height of the spring, and even the rate may be a problem (it may not to).
Those springs wont suit standard, or standard replacement shock absorbers (KYB ETC).
I wish we have a track :)
so the monoflex isn't the best choice for what I'm planning to do, since it's not comfortable on streets, and I won't have the chance to hit any track.
choices are narrowed to Bilstein, Tein Super Street, and HKS Drag (found a used set for sale)
I'll be searching for info about the HKS Drag set, however, your feedback is most welcome :(
cheers,
Super Street. Have been in an R32 GTR with them and R33 GTS25T with them. Ride was sporty and compliant. And i dont believe the Teins will be durable as the Bilsteins but youl will still get an easy 50,000-80,000kms out of them based on the kms i have seen people getting from them
Honestly, after checking all of the choices and prices, the best as I can imagine would be as what Todd replied here in this topic, Bilsteins & Eibach.
I tried to locate some dealers for the bilsteins, but it’s too hard to find a dealer who sells Skylines’ Bilsteins. I found some vendors couple of days ago, but their prices are too much.
50,000 to 80,000 kms is reasonable, isn’t it !!
hey mate,
I would really appreciate a clarification about the difference between the twin tube and the monotube. which one is better, and used for which type of driving.
hello,
if Bilstein is not hight adjustable, then it's out of my list. is the set you have hight adjustable?
Circlip grooved height adj. 2 hrs to adj. height but as with any height adj. gear you will need to do an alignment when you change the set height.
Had mine at 308mm frnt.
going back to 350mm fr, 340mm rr seems to be the best when its there
Nascar use Bilstein, Nissan sell an upgrade susp. pack for 350z range which is also Bilstein-they maynot be the absolute best but they dont cost $50K either so for the cost as to performance I am extremely happy with them- best Ive had so far, had KYB,KONI, & various others and the Bilsteins blow them all away- German Engineering FTMFW
Also being in Middle East you are closer to the Bilstein Factory than we are so contact them directly, You may not have the pollution prob's of Japan so Valves and rubbers will last you a considerably longer time.
HKS will be like Tein- where to service will be a prob for you
Australia is just like everywhere else, when the stocks run out we have to wait for the parent company to dispatch more to here via quota- ie we wait till Bilstein can sell enough to justify the shipment
my 2c
my 2c
I did check the Bilstein website few days ago, it seems that they don't have GTR shocks at the mean time (as the message on their website indicates). however, no harm to contact them. I'll try to call them and check again, maybe they can supply some shocks in reasonable time.
I'll see how it goes, it's eaither the Bilsteins, or the Super Street Teins. I'll let you know guys :blink:
thanks a lot for sharing all openions and information, greatly appreciated.
cheers.
latest update, I got a good deal on a new Tein Super Street kit from Amber Performance. I found them on ebay.
I bought that kit and it should be in the way.
I'll let you know how it goes when I fit it to my car.
cheers.
Edited by evil angel
cheers.
Will keep my eye on this thread for your reply, am interested to see what you think of them :D
  • 4 weeks later...
Will keep my eye on this thread for your reply, am interested to see what you think of them :blink:
Hi,
sorry for being late, I did fit the kit to my GTR. I did some drive test on various streets to see how those coilovers respond.
I got them lowered to the end in three corners, the rear right corner will get lower than the rest if it's lowered to the end, I don't know why, maybe it's something in my car !!! or it's common in all BNR32 with those coilovers !!! I'm not sure. anyway, I couldn't do a 100% accurate measurement to all corners height, it was done using a regular foot measurement tool.
regarding height of the car, you won't be able to completely drop it to the ground, but it's more than enough for normal street use. if it's lower than that, I might suffer when facing any speed control pump on the road. furthermore, I like how my car looks on that height level.
I've tested the drive on different street condition, and different speeds. in all cases, the drive was really comfortable with very minor bouncing comparing with other stiff coilovers.
on normal streets, when I go on relatively normal speed, say 75 - 80 km, drive is smooth with nothing to mark. if I exceed that speed to more than 95 km, drive still smooth, but when I hit a pumpy spot on the road, or to be more specific, when there is a big sharp difference in road height, the front tires slightly touch the inner fender covers. however, I haven't had the chance to play with the damping force level yet. I think it might make a difference on other damping level.
on highways, I reached a speed of 195 km and the drive is comfortable and stable.
body rollover. the old kit I've removed was stiffer, so now I have some body rollover. not like the OEM dampers, but its there. however, as I mentioned, damping force still untouched. and I don't know what damping level I have now. it's because I had a water leak underneath the intake manifold and I had to take my car to the workshop and get it fixed. that thing had interrupted the testing process :happy:
nowadays, I'm taking the car again to the workshop to complete the project and put the rest of the parts. going serious with the GTK 850 turbo, full modified fuel system, AEM EMS,,, etc.
when I have the chance to play with the damping force, I'll let you know.
hey mate, on a 32GTR you don't want to go lower than ~350mm front and rear or the drive shaft angles end up crap.
this measurement is taken from the centre of the wheel to the outer guard (i.e. vertically directly up from the centre of each wheel, to the guard)
hi buddy,
I'll check the distance from the center of the wheel's center cap to the outer guard. but just to make sure, by saying the outer guard, you mean the fender's bow line above the tires (finder lip), right?
cheers
hi buddy,
cheers
yep, that's right
    • Nah. Was just wondering if you were having a small stroke or if there was some slur/gaf/inside joke that I wasn't aware of.
    • That was a fark up, it's Salamanca Place I was thinking of. And now I'm curious as to what potential slur/gaf I have caused with Salamander Road, ha ha!
    • Actually everyone on the roads was really well behaved. The only person that did any minor tailgating was a local hoon in a Turbo Focus. Unfortunately we weren't going the same way so there was no grand initial D touge battle. Lots of people pulled over and let me through. The amount of "Hey man nice car, omg skyline, nice 34 man woo" was suprising. Like really suprising. Like almost annoying. My partner was obviously surprised, she'd never seen anyone in the real world point out the car/like the car/want to chat about the car before, so to have like 3 people per day mention it was notable, I could finally say SEE? SOMEONE THINKS THEY'RE COOL. Everyone was also pretty suprised about the weather. Every day was dry and about ~13-14C. Mount Wellington had a sign that said they close the gates at 9pm and I was heading up there at about ~7:30. It was VERY apparent that conditions were getting significantly worse by the minute on the way up and down. The road on the mountain was terrible though, it's no driving road. I have various suspension related questions now. Luckily it was only about 20 minutes from where we were staying to the top of the mountain as said Google maps. We only had the 2 nights in Hobart. We went to the Farm Gate Market though which was really good - And went down to the Hastings Thermal springs/caves down there during the day. I'd definitely be up for going back again, so luckily there's a few more sights yet to see. Didn't get to do the west coast/queenstown/cradle mountain so this was supposed to be a 'scouting' trip anyway of sorts if I were to one day do/take part in/organize a more car-focused trip. As for the boat, it wasn't bad. Well it was bad, but not in the way you're thinking. We did the night trip which leaves at 6:45 (though you have to be there ~2 hours earlier) and arrives the next morning at about 6am. There is nothing to do on the ship. If you plan accordingly and bring a book/tablet/show to watch/charger you can just chill out, take some Travacalm and just sleep through it. The food there is an extremely basic buffet that costs $32 a plate, or $14 for a $3 pizza. The way back we had a travel kettle and a few different types of cup noodles and made our own tea/coffee in the room. This was a far superior way to do it. At the very least book one of the rooms with beds. I guess as we were in the off season we didn't have room mates. You get an option for rooms with 4 beds (2x bunks) or a room with just the two bottom beds. There's also some option for a deluxe queen bed but it's much pricer. We've been on sleeper trains in Asia before so we figured this is similar (and it was)
    • You just gotta be really, really, really clear and decisive with what you want your end product to be. 99% of people who want this conversion aren't "I want to run a 295 front tyre!" so they don't really need the widebody. They just want the OEM body to look a little less dumpy, so bonnet, bar, skirts job done with some camber, stretch, slam. It's when you want that, but then decide to pivot later you get big problems. See also if you're willing to get an all in one fibreglass bar, and you're willing to accept fibreglass problems like cracking the entire item on a driveway, instead of just a piece attached to the bottom, etc etc etc. Decide this all before buyin'.
