  • Replies 133
Thanx Steve, maybe some other time I can make it to 300 hp :D
but obviously run out of cash , I got some left for fuel :).
Next time I go dyno obviously not Genie (near my house) but ur place :)
Lol , I forgot to pay Paul for dyno cost :) he's going to hunt me with that mighty beast today
haha Erik unfortunately my car was not at Dyno day as it was still having front end repaired after accident ......... but just off the record .... my car looks tonnes better than pauls anyway .... and its black ;) (waits for flamin .... yeah, yeah i know yours does 411 .... but mine still looks better :D ) so just straight swap eh? :D By the time you look at my car theres going to be a few changes too :D
Thanks Steve ..... your support for our entry into PAS is well appreciated by all of us ..... and i can imagine that draggin ya butt out of bed and being at work by 10am on a Sunday wasnt an easy task ! :)
yeah but you would hope it would be getting 400 with how bloody loud that thing is! well at least we now know that the wing will be good for some use, with 400 at the rears it may actually prove usefull :-)
Well done paul I am jealous. but not for long perhaps. Oh and troy if you didn't hear the bang from pauls car this week I am sure you will hear it next week :-p
Onya paul and steve.. well done nice to see a gtst put out that power!
Huge thanks to Steve for supporting us, and allowing us to have free reign on the dyno. An even bigger thanks for not blowing my car up aswell:D
We had quite a few people rock up, and due to the fact that a couple of the PAS entrants weren't able to enter for various reasons we managed to get a few of the interested onlookers to add there cars:D
I wasn't the highest for the day, with Anthony Scalia's Datto taking out top power at 433rwhp, not bad for a backyard job;)
Special mention to Got Boost, pulling 342rwhp in his R32 GTS-t powered by an RB26:drooling:
Thanks alot Dan, I'm just running 260rwhp as my daily setup with the 411rwhp tune only for PAS, until the forged internals are in:D
All my tuning work is done by Steve and he has done a fantastic job, and all of my engine mods are done by Ray Ferrari, proving that even backyarders can get it right:D
Damn there goes any hope of me winning an award at PAS for highest HP 6 was hoping you might blow driving at 360 rwhp plus as an every day drive:bahaha: damn you and your wolf and your backyard mechanic shenanigans!
If it does hold up would there be a quarter mile run with 411rwhp? I would be 1st down there to see how it goes!!! maybe a low 12 or even 11 on the cards would you say?
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
