Keep me in mind guys if numbers are short. Like I said I am hopeless but from the post game report so is everyone lol.
I am 30 years old, 6ft flat and havent played since highschool. But I did win 3 premierships as a whinger and lost one with the ecxuse that the other team was too old lol....
  • Replies 159
Posted Images
Guys, thought I would let you know asap. I won't be able to play this wednesday due to work commitments. Sorry about this, but no reason I shouldn't be good to go next year. Ill call Shane and let him know also.
no dramas, it means i'll get a game again ;)
we'll have 7 this week, anyone else unavailable let me know
this'll be the last game before the break, then we'll have a good 4 weeks to recover
cheers.
it shouldnt be that bad they r only the next position up on the ladder.... i'm looking forward to it. might bring my asthma pump this time instead of leaving it at home lol im gonna get there at 6pm justin and AP do u wanna meet up at the same place as last week at say 5:30?? or just meet at the stadium?
yeah i'm up for a pre-meet...
you know, with all the police presence around and seeing as though, more often than not, we might keep meeting up before making our way to the stadium, maybe we could start thinking about carpooling next year?
just a thought... *shrugs*
sounds like a great idea
Can't make it due to work commitments. Changes in shifts, trainging, etc. Hence the post earliesr in the week. Sorry man. No reason why I shouldnt be right for first game after the reak though.
  • 1 month later...
yeh im in , cant play the 4th of feb though as im goin away to echuca for the southern 80 and leaving on the 3rd feb coming back on the 11th but will be able to play the 11th as i will be back just after lunch.
10.15......CCCCCCCCCAAAAAAAAAAAAAARRRRRRRRRRRRRRRNNNNNNNNNNNNTTTTTTTTTTTTTTTTTTT
TTT
Its past my bed time. Sigh, see you then.
yeah I'd imagine you would need LOTS of beauty sleep :blink:
sweet see ya both there... we need a couple more tho, AJ back from holidays yet?
Chris you coming down? Justin? Shane?... Bueller? Bueller?
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
