Guys
I have aquired a set of "quite useable" 87mm CP Pistons. One of the rings is ROOTED though and thought it best to buy a complete set. I was reading on the hi-octane website (under CP Piston rings):
"Manufacturer: CP or ACL. Depends on our current stock"
http://hioctaneracing.com.au/eshop/product...products_id=633
Does this mean ACL can also supply a replacement ring set for these? Or is there any other option other than the CP rings? The top ring is 1.0mm and the 2nd ring is 1.2mm
Any help would be appreciated!
Cheers
Steve
https://www.sau.com.au/forums/topic/247675-replacement-rings-for-cp-pistons/
for Total Seal rings (including their patented Gapless rings) try www.performancewholesale.com.au
be careful with which rings you buy, as different brands will have different axial widths (ie: the depth of the ring into the piston groove)
Make sure you check this too.
i'm using a set of acl rings (also known as mahle rings) in a set of CP pistons. The acl rings are actually listed for a mitsubishi 4cyl engine, so i had to get 2 sets, bout $150 from memory
both acl & cp top & second rings are nitrided but the oil control ring in the acl set carries more tention ( personal preference but i like slightly more tention)
ACL rings seal very well and come highly recommended for street engines
Do you recall which mitsubishi it was?
The ACL RB26 pistons take a 1.5 top and 1.8 2nd ring, while the CP have a 1.0 top and 1.2 (I think) 2nd.
i cant actually remember. if you can find an acl catalogue they are all in there
correct...nice thick rings provide a good seal.
the CP's 2nd ring is 1.5mm from memory
Edited by DiRTgarage
I just measured - the CP's I have a 1.0mm top and 1.2mm 2nd ring (sames as a set of Wisecos I have...)
shame I cant jam a big fat ring in there :)
shame I cant jam a big fat ring in there :P
are they not new? The new CP's run thicker rings as i tried to use an older set of rings on NYTSKY's engine (i fu(ked one putting them in) and they were too thin. Had to buy a complete set of rings from Quantum just to get 1 second ring out of it...bugger!
could be older style perhaps. The pistons themselve dont appear to have done much work. But definitely thinner rings
are they not new? The new CP's run thicker rings as i tried to use an older set of rings on NYTSKY's engine (i fu(ked one pu.tting them in) and they were too thin. Had to buy a complete set of rings from Quantum just to get 1 second ring out of it...bugger!
  • 9 months later...
Sorry to revive an old thread. However, I am trying to figure out if I have a newer set of CP pistons or not. I bought my CP pistons for my RB26 new back in September of 2007 and have been sitting in the box ever since. I measured the rings for craps and giggles and found that I have a 1.2mm top ring and a 1.5mm second ring. Do I indeed have the newer set of "thicker" rings/pistons?
And on top of that, should I upgrade to a set of ACL rings or others before I slap in those pistons? Thanks all........
they are the new design piston...the rings you have will be fine.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
