hi there need help from anyone that has a factory exhaust with 3 cats on it 2 cats have ca/5005 as the model number and 1 cat has ca/91006 need this to clear a defect and my exhaust only has 1 cat on it from the dealer.
anyone one that can help me i would much appreciate
would anyone lend me their factory one
cheers
damo
https://www.sau.com.au/forums/topic/247755-nm35-need-help/
cheers
damo
When is the deadline, I am looking at upgrading the exhaust soon but it would be after Christmas.
https://www.sau.com.au/forums/topic/247755-nm35-need-help/#findComment-4301457
cheers
damo
I think you will find the ca/91006 on your dump pipe.
Unfortunately I can't help you with the rest (1. Live in VIC and 2. "Original" exhaust has been thrown out when upgraded).
Worst comes to it, you could always pick up a second hand one via Import Monster. I have seen them sell for $60AU (not including shipping of course).
Sorry I couldn't be much help.
Out of curiosity, which exhaust do you have that got you the defect?
https://www.sau.com.au/forums/topic/247755-nm35-need-help/#findComment-4301651
I took the 3 cats of and replace them with a highflow.
Gave the old cats to Ben at North Shore prestige.
He may still have them
m
cheers
damo
https://www.sau.com.au/forums/topic/247755-nm35-need-help/#findComment-4302001
I second that...Turbo Back Dump, Cat and Fujistubo Legalis R....and its still reasonably quiet.
Actually, I have the stock dump, Kakimoto front pipe (no cat) to Legalis R.
Absolutely gorgeous sound, quite a bit deeper than just the Legalis from the stock front pipe (which is the setup my mate has).
Not the greatest of shots, but you get the idea.
https://www.sau.com.au/forums/topic/247755-nm35-need-help/#findComment-4302266
hey do u guys go cruzin much?
Damo, have a quick look here in the "Calling all Sydney Stagea owners" thread - I head up almost every week, Alex "CL11QE" is also a regular, and the crowd is growing.
Come along if you can, we're a friendly bunch and it's a good night out!
https://www.sau.com.au/forums/topic/247755-nm35-need-help/#findComment-4303374
My exhaust is cracked so i'm about to look into an aftermarket replacement. The rear will be a Fuji Legalis-R but i dont know what to put as a front pipe and dump. Tony, your custom dumps look like the part with having that long secondary outlet (better than the HKS ones). Where did you get that made up if I may ask.
And can anyone recommend a suitable front pipe?
thanks
https://www.sau.com.au/forums/topic/247755-nm35-need-help/#findComment-4305405
thanks
You will find the details of Tony's dump & front pipe here;
http://www.skylinesaustralia.com/forums/in...t&p=4253896
If you want a JDM front pipe, Kakimoto are the only ones that make one.... no cat though.
Edited by iamhe77
https://www.sau.com.au/forums/topic/247755-nm35-need-help/#findComment-4305611
Ok I just ordered the dump/front combo with metal cat and ceramic coated from Livo Exhaust for $990 fitted, which i find to be good value considering a metal cat alone costs about 400 bucks.
Thanks for the info, it was great help! And thanks for the Livo Exhaust details as well Tony :)
https://www.sau.com.au/forums/topic/247755-nm35-need-help/#findComment-4305941
Thanks for the info, it was great help! And thanks for the Livo Exhaust details as well Tony :D
Hi Euge,
That is good valued & the guys do a fantastic job, hows your GTR project going???
https://www.sau.com.au/forums/topic/247755-nm35-need-help/#findComment-4317267
Hi Euge,
Hey Tony!
Just got the dump and front done including a metal cat on Saturday and I must say, what a difference! Turbo spools up quicker and pulls bloody harder than stock. And I still have the stock cat-back on as well. The Fuji will arrive in Jan so I cant wait for that.
Btw I will have a spare stock exhaust once i get the Fuji. I just cant give you the front part cause it was rooted already.
Been holding off with the gtr due to finances, but now that i've sold one of my cars, it's back on track! ;)
So hopefully motor is coming out over next couple of weeks.
https://www.sau.com.au/forums/topic/247755-nm35-need-help/#findComment-4317783
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
