for all you guys wanting to run a holset on your rb (or other engine) i can draw a flange adapter in cad so you can go to any laser cutter and get one made. someone just needs to give me the dimensions of the holset flange. i already have the t3, t4 etc drawn already.
  • Replies 198
Thanks Crack, the HX35 flange is already T3 divided, but a spacer will be needed if using stock manfold. can anyone tell me if it will fit in a stock low mount position on an R33 GTS25t? :blink:
thats cool. you then need two t3 divided flanges. i have that as a dxf file.
do all holsets have a v-band outlet? if not if someone has one out of the car, give me the dimensions and i'll draw it up for you
thanks works, yeah i have read his thread, my concern is the different size of engine bays and block heights, i have been told by others that i will need to cut into the subframe or engine mounts which i don't really want to do. was hoping there was someone who has tried to fit one already. anyone?
  • 1 month later...
I have an R33 RB25 on the engine stand right now. It's almost ready to go into my 280Z. To answer your question, I have a 7-blade HX35 and it does not clear as a direct bolt-on. For the oil feed, the factory line fits, but the stock RB oil feed banjo bolt on the stock turbo is 12mm x 1.25 while the Holset requires a 12mm x 1.50. The oil drain line fits up as per factory. For the eliminated coolant lines, a 14mm x 1.50 oil drain bolt will plug the banjo hole off on the block.
I have seen people find an appropriate banjo bolt from another application and made it work. I have also heard people take a standard bolt and drill it to banjo specifications. Note that the stock banjo bolt acts as a restrictor. I don't think the Holset really needs a restrictor to avoid issues, however.
The only issue is that the turbo fouls the exhaust manifold at the compressor cover. If you clock the compressor output straight towards the block (in other words, a useless clock position) it will clear since the radial diameter changes, etc. With the compressor outlet pointed down, it will not clear. I suspect you merely need another T3 flange to be used as a spacer when you mount the turbo to get it to clear, but I have not tried this yet. Note that, as others stated, the turbo and the stock exhaust manifold are both twin scroll. I have not found a twin scroll "u-weld" flange to space it out. Likewise, you will need longer studs for the exhaust manifold.
Note that the exhaust manifold studs are dual thread. They are 10mm x 1.25 on the turbo side and 10mm x ??? on the manifold side. It's a coarser thread spec, but I have not measured it yet. The holes in the exhaust manifold for the studs are obviously blind, so you could just get some high grade threaded rod and cut them to length, etc.
Please note that I have NOT tested fitment with the factory engine mounts, as I am doing a swap into another chassis and did not use the original mounts. I have them however, so I can test it out if anyone is interested.
As a side note, another nice thing about Holsets is that the compressor wheel is balanced individually (on the '35' sizes, and some others) and the turbine wheel and shaft assembly is balanced individually. This means you can rebuild it without indexing or having it rebalanced. Just pull it apart, stick the new bearings in, and slap it back together.
Edited by WizardBlack
Would be much appreciated if you could fit up the old mounts Wizard, i am wanting to keep it low mount and this will determine whether i can go for an hx35, if it requires modification i'll probably go for something different. cheers!
A few months ago I said I would post a dyno chart of my HE351 RB20. I'm a little late, but here it is:
327 RWHP and 255 FT/LB
My spark timer is broken, so the RPM scale is a little screwed up. It should end on 7000 RPM.
This is on a mustang dyno at about 580 meters above sea level.
RB20 stock internals
Holset HE351 from a Dodge RAM - NOT the variable vein model
4" Downpipe / 3" exhaust
4" Intake
440cc 7MGTE Injectors
ECU Remap
GTR Fuel Pump
Everything else is stock
This is the first car I have ever tuned (without help from a professional tuner). I'm pretty happy with the results, but I know it could have done better.
It was running 18 psi (1.25 bar). I pushed it up to 22 psi and blew the rings out of the 1st cylinder. I have since put a new motor in, cams, and changed back to an RB25 turbo. I will rebuild and run the holset again. But I don't have the money for a rebuild right now.
Im assuming you are using the stock wastegate, and not an external. IMO this could well have contributed to te failure of cylinder #1, as the manifold pressures of cylinders 1,2 & 3 would be far higher than 4,5 & 6 as the wastegate only feeds off those cylinders, which would mean that the tune would be conservative on the back 3 cylinders.
Stock WG actuator, using internal Holset WG. My wastegate line was pulled right off the turbo (see pic).
How does the stock internal WG feed off 1-3? My stock rb20 and rb25 turbos have a feed line right off the turbo, just like the Holset. I always thought that on a straight 6, 5&6 would have higher pressure.
I just thought I pushed too much boost and my timing map was a bit aggressive.
  • 4 months later...
mad old thread revival.
he is talking about the actual flapper on the turbo, only bleeds exhaust off 1 side of the split pulse housing.
  • 1 year later...
Bigalow, I have a modified Holset He351vg turbo that I have been developing with a specialist in Canada. This is a HX40
With a unique pneumatic VG control system fitted. This same turbo on a bog stock supra Tt lump made full boost at 2800rpm!! It's destined for my RB26 soon !!!
You Godzilla32 in GTROC? I was reading the thread yesterday... Please excuse my thread jack but it seems like petro isn't good with VGT per the pressure in the manifold and I doesn't seems very reliable.
Bigalow, Yeah thats me. The Supra guys have been using these Holset VG turbos for a long time now with no issues....I used to work at Holset in the UK and I was involved in the development of this HE351VE. The materials used to manufacture these things are the same if not better than those used in petrol turbos. Sure EGT's are higher in petrol applications but as all of the materials in the Holset Turbos are exactly the same as petrol turbos this is a lame ass excuse used by haters!!!! lol!!
I don't trust UK products.
Joking but the Supra is a different application than the RB. I was thinking about buying a GTX turbo (by Garrette) so I'll probably stick to that as opposed to being a VGT pioneer.
You say teh materials used are the same as the petrol, but what are petrol vgt vanes made of?
    • Wow, thanks for your help guys 🙏. I really appreciate it. Thanks @Rezz, if i fail finding any new or used, full or partial set of original Stage carpets i will come back to you for sure 😉 Explenation is right there, i just missed it 🤦‍♂️. Thanks for pointing out. @soviet_merlin in the meantime, I received a reply from nengun, and i quote: "Thanks for your message and interest in Nengun. KG4900 is for the full set of floor mats, while KG4911 is only the Driver's Floor Mat. FR, RH means Front Right Hand Side. All the Full Set options are now discontinued. However, the Driver's Floor Mat options are still available according to the latest information available to us. We do not know what the differences would be, but if you only want the one mat, we can certainly see what we can find out for you". Interesting. It seems they still have some "new old stock" that Duncan mentioned 🤔. I wonder if they can provide any photos......And i also just realized that amayama have G4900 sets. I'm tempted too.
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
