hey just wondering if flutter is bad for the car and if so what damage will i be causing the engine turbo etc. the flutter effect is when the small breather hose is disconnected off the stock BOV and bloked off both ends....
please add in your 2 cent :spank:
https://www.sau.com.au/forums/topic/247829-flutter/
Ask any VL driver, flutter is SIK BRO!!!
Flutter it the sound made by air pressure that does not release when you close off the throttle body (usually because of a lack of BOV). The sound is the air rushing back from the throttle to the blades of the turbo, and the air gets chopped up.
There IS pressure on this, and it does cause undue pressures on the turbocharger blades, possibly causing minor damage, but my personal thoughts are that unless there is already issues with the turbocharger(s) or the units are old, you shouldn't have much trouble.
B.
https://www.sau.com.au/forums/topic/247829-flutter/#findComment-4302609
In my R31, flutter was so 1989 :(
Sounded awesome, and that car ran beautifully with no BOV. However, my 33 does not like its BOV being blocked off, driveability suffers. The ECU must be more sensitive to the intake tuning.
Myth that no BOV will kill your turbo is BS. My 31 ran 1 bar for 3 years and never had an issue.
https://www.sau.com.au/forums/topic/247829-flutter/#findComment-4303336
In my R31, flutter was so 1989 :)
Edited by iamhe77
https://www.sau.com.au/forums/topic/247829-flutter/#findComment-4305859
Lot of info here about flutter.
http://www.nissansilvia.com/forums/index.php?showtopic=28060
By removing the vacuum hose ontop, the bov can still vent due to the high pressure air pushing the piston in the bov up.
Best method is to put a metal plate between the bov and the cross-over pipe.
Expect the car to stall when coming to a stop and becoming real sluggish. The stock ecu hates flutter and will make the car shitty to drive.
https://www.sau.com.au/forums/topic/247829-flutter/#findComment-4306018
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
    • What Duncan said sounds right. Also, it looks like they only have the driver's mat. Not the rest. Because looking at the diagram: KG4911 is just the mat for the driver. KG4900 is the full set if I'm not mistaken and discontinued.   But, it looks like they may still have the full set for the manual S2. Might be worth checking for the other models as well as they seem slightly different. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/misc/G49 Man, I'm tempted.
    • I dunno about that as a blanket statement. Pitwork is Nissan's "Nissan genuine" thing, and for stuff like timing belts, I have found them to be excellent. Of course, for things like oil filters, you always use proper trusted brands anyway, not whatever the OEM has taken to using.
    • Ahhhh... If you were putting 12V to the led in there, that's likely made it very unhappy. Chances are how you put power, was 12V across an LED that's meant to only have about 20mA through it at peak, and a forward voltage of about 1.8 to 2.4 volts. That circuit is likely only a 3V3 circuit, and will have a resistor in series with the led too. That's my guesstimate on that light, without having touched one.
    • Another vote for installing them and see how you go.  I mean, you already own them, why would you not fit them?
