I am after a R32 Skyline turbo manual, i would prefere damage/blown motor but one in good condition would also be fine.
However i am looking for around the $14 000 - $16000 dollar mark atm, i dono if its possible to even find a r32 for around that price especially in WA but its worth a try.
https://www.sau.com.au/forums/topic/24791-r32-skyline-turbo-manual-wanted/
yeah nice car adam but too exspensive for me atm.
I am looking for one with damaged motor because i can fix it myself with the help of my dad who can also get me cheaper parts so that way i could have a nice recon motor maybe with some mods done at the same time, also a 3 litre conversoin would be nice but i dono about that yet. My mates dad has done the conversion so maybei could get him to help
