Item:
R34 GTR Wheels with Bridgestone Potenza Tyres
Condition:
Like New
Price:
$2500 for wheels and tyres or $2600 if you want the GTR caps also
Wheels are at my brothers house in Sydney, GTR caps are at my house in Newcastle.
Prefer a pick up for the wheels and tyres, I can post the caps if you want them also.
Contact:
PM or Reply here
Pics
Tiny scratch on two wheels like what can be seen below, hardly noticeable
Tiny gutter rash on one wheel, hardly noticeable
Tread
Optional GTR caps
Re the tyres, when were they purchased? How long have they been on the rims? How long since they're been driven on?
Thanks.
Tread is plenty as can be seen in the pics.
My car came from Japan with the wheels and tyres on it ~6 months ago so I have no idea how long the tyres have been on the wheels. The wheels and tyres have been off my car for the last 2 months as I bought 19s.
Thanks. I bought a mint set of R34 GTR rims with RE01 rubber, which on very close inspection had cracks all through them (I bought them in the dark!! My bad. Still, got them for less than $2k) as they was so old (I think they were the OEM tyres). Can you comment on how the rubber looks and feels. The above were 'hard' and I'd suggest well past it.
Thanks.
Thanks.
^^^ I wonder how those RE01Rs were stored?
I've just now replaced my OEM RE01R Potenzas after the car had done 29000Km and they had no cracks. Such a grippy tyre and...
very very expensive.
Bakes' price is extremely reasonable with that sort of rubber on it - and plenty of it.
When you say oem RE01R, which car do you mean came out with those tyres from factory? I'm pretty certain gt-r's didnt come with those tyres from new. I think it was G3's or something similar. I know at least it was a Potenza range.
does it take much to fit these upto a 32, are they the same offset?
They fit straight on, the offset looks better on the 32 than it does on the 34! go a 255/35/18!
Yeah, 32 GTR. I'd bet they're a struggle on a GTST. Ideal offset for the 32 GTR is +20, so you do need the extra tyre width to make em sit flush(ish). I've got 245 R Specs on mine which'll do the same job. Or spacers, which I've not researched and am not convinced about.
They will fit easy on an R32 GTST with 235/40 tyres, if you want to run 245 then best to roll the inner lip on the rear guards. If your putting it on an R32 GTR then yes easy fit, sometimes the wheels get a bit lost in the guards though..
^^^^^really?? didn't know 9" on front with +30 offset would fit on front of a 32 gtst? would they rub or scrape on anything when at full lock without any mods though?
Plenty of people run a 9" with a + 30 offset up front, R33 GTR wheels are 17 x 9 + 30! Depends on how low you go, if you go really low you will need to remove guard lining, don't go too big with tyres as well, 245 MAX but I would recommend 235 for a neat fit
PM me if you want some more details, thread will go off topic otherwise
    • sold listed as a Tomei LSD 1.5 Way For 1998+ Nissan Skyline ER34 25GT RB25DE w/Open R200 https://www.ebay.com/itm/174006114594?campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=&mkrid=711-53200-19255-0&loc_physical_ms=108689&loc_interest_ms=&campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=71883f2ccc571356e0a757bc7adfdde2&mkrid=710-53481-19255-0&loc_physical_ms=108689&loc_interest_ms= it went in like butter all gears, alignment, back lash etc, rotation and clearances correct, and if rolling all rotates smooth and free when coasting down road , clutch in or out over 10 mph smooth... its the binding, clunking and jerking from a stop that is most concerning, also seems like its going to tear the tires off in 10 miles of normal road driving.
    • What 1.5 way? There's no such thing really as a 1.5 way, just different ways of explaining 2 ways with different ramp rates. HOWEVER. In any driving in a straight line your 1.5 or 2 or 1.7 way should have no clunking at all. With the clutch fully depressed the diff should be silent (unless it's welded but I'm assuming it's not). Something aint right here.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
