Hi guys got myself a intercooler package at VMS and just thought all you r33 owners would love to see some pics of the work that VMS have done. This package has made a once sluggy r33 into a bullet and still more mods to come.
VMS is located in Footscray, Melbourne. See David or John if you would like a intercooler package. Just tell em Amit sent you.
Heres the pics below, Comments please.
  • Replies 41
well this was custom installation and stuff around the $1600- $1800 mark. But its worth every cent when you hear the intercooler sound and when the car keeps on pulling you back with boost never dropping.
But they have other packages and cooler sizes going for $1200 - $1500 installed and tuned.
I think they split into two pipes just after the turbo so that two pipes go out the engine bay (out both the original send and return holes of the factory cooler) and into the new cooler. From a flow viewpoint, i can't see that splitting it can be any better than one single pipe.
When you split it so close to the turbo, the air effectively fills double the volume, which (when fluid expands to fill a void) will cause a pressure drop. So now we have less pressure (but more flow) along two pipes, with added turbulence at the split (remember this is why when we have a separate wastegate dump we join it back to the exhaust a fair way down from the turbine so there is no turbulence). Compare this to the pressurised flow of a single pipe - higher pressure, but no disturbed flow or turbulence until it reaches the intercooler.
So when the two pipes reach the intercooler, the flow does not have to distribute itself as much inside the end tanks, and it should in theory flow much more distributed across the IC core. However, this is where fluid flow research is at its best - i am sure that HKS, TRUST et al have done hours of flow testing to ensure their endtanks distribute flow evenly across the intercooler core. Many companies both local and in japan believe that this is the key to a cooler that flows well, cools well and does not restrict flow too much - end tank design. So now the single pipe IC has reached the cooler, and if the endtank is designed correctly the air will distribute across the core (with a fair amount of turbulence. This pressure drop and turbulence will occur with both styles of cooler.
So the charge of air passes through the core at a lower pressure and is collected at the other endtank, reducing the volume (to outlet pipe volume) and hence re-pressurising the air. Now what i am saying is a well designed twin entry should perform as well as a single entry cooler, but there is more scope for variation. This system would work better for a very big turbo, as it will keep pressures up and air flow speed up in the twin pipes before the cooler.
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
