Ok got a bit of an odd idea lately.
Doing a rb30 conversion in my 32 soon (gts-t) and as my original rb20 gearbox is slowly on its way out ie buggered syncros etc ive decided i will change that at the same time. I was just wondering if anyone has used a 31 box in a 32.
also if anyone has a turbo (local) 31 out there how much power can the box take.
I know a 25 box is a much more sensible proposition but at this point in time i would simply like to know if a 30 box could handle the punishment as im building a turbo SOHC rb30 for my brothers Datsun and he doesn't really want to fork out the extra cash for a 25 box.
any help would be much appreciated thanks guys
https://www.sau.com.au/forums/topic/248261-r31-local-gbox-stength/
do it till you smash the MF5, then fork out for an upgrade. those boxes are worth f*ck all second hand, so might aswell use it till its no good. i *think* you can still use the same clutch and flywheel when you change the box over too, so theres no issue if you want to buy a tough clutch. although double check on that as i cant be sure
the R31's i believe should have pretty much the same box as the 32, just with a single syncro on first and second, overall strength, im lead to believe, is pretty similar
I have an R31 box with a hardened gearset in my R32 that is powered with a RB30det making 260odd rwkw and well over 600nm of torque.
I bought the box recoed and the gearset had been hardened, cant remember if it was nitrided or what was done to it but its been in there for 15 months doing its duty. the syncros are not fantastic but it has held the power fine.
probably not an ideal box but should hold together for a decent amount of time if it is treated with respect.
what is exactly about the rb20 boxes that break?? stripped gears?? snapped shafts?? etc??
i use my 32 for drift mainly... not much for drag.
just wondering what it is that is crap about the rb20 boxes and under what treatment?? snapping gears?? dumping clutch?? clutch kicking?? or is just shear power??
and yes rb25 and rb20 have same clutch.
cheers
Linton
I have busted 3 of them
1. input shaft bearing shat itself and the box became super noisy and crunchy.
2. blew iself to bits and a hard chance into 3rd. i was un able to tell what went wrong woth it as it was shattered. gearsets and syncros everywhere
3. stripped the teeth of 2nd gear..
all these were done with rough treatment and a heavy single plate with an rb20 making 240rwkw. if you treat the box well and no flat shifting it will last quite well
i have built an rb30det that has the r31 box behind it, holding up fine under moderate power.
however the car doesn't have an lsd and uses street tyres and organic clutch, so more then likely the reason it is still alive.
slicks/semis, lsd and button clutch would equal instant bye bye i reckon.
by the same token there was a guy with a turbo r31, slicked and lsd, launched it and actually popped the 4 pinion diff, how the diff went before the box is anyones guess, but i put it down to luck more then a testament of the stock r31 box strength.
i have a 31 box in my r32, the clutch and flywheel's are different and are not interchangeable with r32 or r33 boxes.
i have just done a clutch swap 10000k ago and im starting to get a noise when its engaged im thinking its the input shaft as the thrust bearing was replaced not long ago...
it likes to slip out of 5th sometimes too.
^ thats funny , i've put a r31 gearbox in an r32 before and it bolted in just like the r32 box :thumbsup:
the syncros are the main difference , other than that its the same box as the 20 :D so it should handle the same power
Edited by toffy
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - there is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
    • no one recommending speedtek gearsets?   i'm in the same boat as Cosline but rwd, I am holding boost back in third to 600nm at the hubs to save the gear as i make nearly 750nm at the hubs on a mainline
