hey everyone yesterday i was driving not to far from my house and there was a big bang like a backfire didnt think to much of it but then it happened again.My dad was following me and said there was like a big cloud of brown/black smoke.I pulled into my driveway only to notice one of my exhaust wheels sitting inside my cannon.So obviously i was cut and stressin out.But more importantly im stressin more about if anything went into my motor.The wheels that ended up in my car is pretty much complete but has chips of it etc.The car drove normal but wouldnt boost so i nursed it home n turned it off.When tryin to boost it was like aa high pitch noise with a type of rattle to it.Has anyone had this happen to their gtr before any help or information would be greatly appreciated
https://www.sau.com.au/forums/topic/248376-r32-gtr-turbos-go-bang/
Hi
Yes I have had this happen before, however I was one of the few unlucky ones and the ceramic dust generated when the turbine smashed into the turbine housing and took out my engine. I an just getting the rebuilt engine back together now.
Most people don't have this problem (engine being damaged by ceramic dust) but I think we are going to start seeing an increase in (especially R32) GTR ceramic turbo failures they are simply getting past their designed working lifetime.
My engine died immediately as a result of lost compression. I was backing off at relatively low RPM when mine let go, which I'm confident is one of the only conditions which would allow significant amounts of ceramic dust into the engine.
I would definitely suggest checking your compression, perhaps leak down test. I can sympathize with your situation, it sucks. Just get some garret 2860 -7's (if you stick with a std engine).
Hope it all goes well.
Edited by OzLeroy
When you pull the turbo's check the comp wheels, if they are stuffed then a compression and leak down test is a must.
HKS GT-SS's or Garrett 2860R-7's (also R34 GT-R N1's) are what you want if you're staying on standard internals. Either of these wcan pull up to 330awkw's with the right supporting mods. 300awkw's is easily achievable on each with the right mods too.
An even cheaper option is to go with R34 GT-R turbo's they're still ceramic but are ball bearing and cam be had dirt cheap from someone upgrading. You can easily pull 250awkw's on these with safe boost levels.
Good luck mate and let us know how you go. Pics are always good too.
Cheers
Yeah, had this happen. Some say there will be a problem. But when my rear turbo went there was no residual damage. As for replacement turbos, it all depends where you are going and how much hp you want....2860-5 were my choice. 430whp on standard internals, but these will support more power on a rebuilt or stroker engine down the road (when the $AU stops getting butt raped :D )
with regards to r34 gtr turbo's can they handle more boost being ball bearing ? I see alot of r34 gtr stock turbos being boosted to 17psi with no problems. I know they are still ceramic but i've yet to hear a r34 gtr turbo damaging engines like the r32 and r33 gtr's.
Can anyone shed more light on the max boost of stock r34 gtr turbos.
cheers all
Cheers
check and see if the comp wheel is blown. if thats in tact u shouldnt have a problem. Just replace your turbos
Not quite.
Its the exhaust wheel failing that causes the damage
cheers all
They are just 10 years newer, doesnt mean they wont do exactly the same thing. Its just going to take a while.
So the 'max' IMO is the same.
Is that the case Nismoid? I thought it was the comp wheels letting go that allowed the engine to ingest ceramic dust? Do they suck in junk from the exhaust wheel letting go via back pressure?
Yeah what Nismoid said is accurate. They're newer so will last longer but should still be treated with the same respect. They'll spool a bit quicker being BB but they're still ceramic.
well 2 of the last motors ive pulled apart that have had blown turbos in there life show peices of ceramic on the head quench areas and inbedded in the pistons, u can tell because its usually on only the front or rear 3 cylinders and when they deck it u can still see pitted holes and the decking machine doesnt like the ceramic pieces lol.
You answered your own question :P
Ceramic dust can only come from the exhaust wheel, so its gotta be coming from there in this instance... as we've heard a lot where there is ceramic dust on the rear of the 3 cyclinders as its usually the rear that lets go... but can go either way
The comp wheel isn't ceramic, cant be coming from him! :)
You answered your own question :)
The comp wheel isn't ceramic, cant be coming from him! :P
Ahh thanks for clarifying :P
  • 2 months later...
mate,
sorry to hear about the turbos, i had the same thing happen to me,
i put my foot down in my '89 R32 GTR around a corner and the power just cut on me and a huge ploom of black smoke came out the exhaust. then it sounded terrible and wouldnt want to boost.
i've got a pair of Garrett GT2860R-5's sitting next to me, that i am getting installed in just over a week.
the worst part about it was that the turbos blew on the friday and i was getting it dyno tuned on monday which was my birthday, so its a pretty expensive birthday present to myself.
i was only running stock boost too.
hopefully i can get some real good power out of the car now.
BREZZA
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
